vat_file_io_adsp_bf609-cces run failed
Question asked by roilandtangyu on Jun 20, 2013
Latest reply on Jun 21, 2013 by roilandtangyu
when I try to run the vat_file_io_adsp_bf609-cces demo on BF609-ezkit board, the application failed at ConfigureSoftwareSwitches() functions, I found that when program try to call adi_twi_Write() function, the application will run failed. here is the error messages:
A fatal error or exception has occurred.
  Description:   A data CPLB miss has occurred without a corresponding CPLB entry.
  General Type:  RunTimeError
  Specific Type: DCPLBMissWithoutReplacement
  General Code:  0x8
  Specific Code: 0x320
  Error Value:   0x9149ff8c
  Error PC:      0xffa0de1c
Is it because of not correctly set the EZ-Board SWITCH SETTINGS? here is the demo "readme":
Hardware Setup:
ADSP-BF609 EZ-Board SWITCH SETTINGS
SW1:  1-ON 2-OFF 3-ON 4-OFF 5-ON 6-OFF 7-ON 8-OFF
SW2:  Boot mode rotary wheel in position 1(Flash boot)
SW3:  1-ON 2-OFF
SW4:  1-ON  2-OFF
SW5:  ALL OFF
SW6:  Press Button
SW7:  Press Button
SW8:  Press Button - Reset switch
SW9:  Rotary wheel
ADSP-BF609 EZ-Board JUMPER SETTINGS
P1 : Not Connected (Default)
ZP1: Not Connected (Default)
P10: Connected (Default)
P11: Connected (Default)
P12: Connected (Default)
P13: Connected (Default)
P14: Connected (Default)
P15: Connected (Default)
P16: Not Connected (Default)
P17: Not Connected (Default)
I confused that if I need to press SW6 and SW7 button before i run the demo?
BTW:
I close the ENA_USBIO macro, and not use the ucosiii.
