some questions about ifft_fr16
Question asked by Ethel on Apr 19, 2010
hi, recently I'am learning about the FFT. I have some questions about the example code given in the ifft_fr16(...) help document. The example code is as follows:
#include <filter.h>
#define  N_FFT 64
complex_fract16   in[N_FFT];
complex_fract16   out_cfft[N_FFT];
complex_fract16   out_ifft[N_FFT];
complex_fract16   twiddle[N_FFT/2];
int               blk_exp;
void ifft_fr16_example(void)
   int  i;
   /*  Generate DC signal */
   for(  i = 0; i < N_FFT; i++ )
      in[i].re = 0x100;
      in[i].im = 0x0;
   /*  Populate twiddle table */
   twidfftrad2_fr16(twiddle, N_FFT);
   /*  Compute Fast Fourier Transform */
   cfft_fr16(in, out_cfft, twiddle, 1, N_FFT, &blk_exp,  0);
   /* Reverse static scaling applied by cfft_fr16()  function
      Apply the shift operation before the call to  the
     ifft_fr16() function only if all the values in  out_cfft
      =  0x100. Otherwise, perform the shift operation after the
    ifft_fr16() function has been computed.
      out_cfft[i].re = out_cfft[i].re << 6; /*  log2(N_FFT) = 6 */
      out_cfft[i].im = out_cfft[i].im << 6;
   /* Compute Inverse Fast Fourier Transform
      The output signal from the ifft function will be the  same
      as the DC signal of magnitude 0x100 which was passed  into
      the cfft function.
  ifft_fr16(out_cfft, out_ifft, twiddle, 1, N_FFT,  &blk_exp, 0);
Here is my question:
(1)as the document said, cfft_fr16 will scale the intermediate result according to the scale mode to prevent overflow. But there is a for-loop following the cfft_fr16 function, I think the result will be overflow again. I can't understand it.
(2) the annotation part that just above the for-loop say if all the values in out_cfft = 0x100, user should apply the shift operation before the call to the ifft_fr16, otherwise, perform the shift operation after the call to ifft_fr16. What is the reason? In fact, I put the shift code after the call to the ifft_fr16, I also get the right result.
(3)when I change the N_FFT >=256, the result turns to be 0.
(4)Sometimes I think we should apply the shift operation after the call to cfft_fr16 and the call to ifft_fr16, cause the two function both scale  the intermediate results. But it won't be correct, right? cause with just one shift operation, we get the right result. I just can't understand it.
(5)when I change the scale mode to 2 and 3, and 6 in for-loop to blk_exp, neither I put the shift code before the call to ifft_fr16 nor I put the shift code after the call to ifft_fr16 wouldn't get the right answer.
Thanks in advance.
