Error using macros with structures
Question asked by kbrafford on Apr 13, 2010
Latest reply on Apr 15, 2010 by kbrafford
I am trying to use the <cycle_count.h> facilities in my application.  In my C file I have a static structure that I use to hold all of the data use in the module:
static struct driver_data {
   unsigned short int                 channel_number;
   union {
      cycle_t           cycles_64;
      unsigned long int cycles_32[2];
   }                                  final_count;
   cycle_t                            start_count;
} mb_self;
Early in my application I want to initilize my mb_self.start_count field, so I do this:
START_CYCLE_COUNT(mb_self.start_count);
However this causes an exception with the very first [P1] write, even though it appears that the compiler correctly has P1 pointing to a point 10 bytes into the mb_self structure.  That is, mb_self is located at 0xFF805560, and the assembly for the START_CYCLE_COUNT looks like this:
P1.L = 0x556A
P1.H = 0xFF80
R2 = CYCLES
R1 = CYCLES2
[P1] = R2                ; // BOOM, ROASTED here
[P1 + 0x04] = R1
However, if I take my cycle counter variable out of the structure:
} mb_self;
union {
   cycle_t           cycles_64;
}                                     g_final_count;
cycle_t                               g_start_count;
    START_CYCLE_COUNT(g_start_count);
the START_CYCLE_COUNT macro seems to work.
The same problem then still exists for my union.  If I use g_final_count.cycles_64, it fails.  But if I make g_final_count be its own global cycles_t type, then the macro doesn't except.
Why is that?
--Keith Brafford
