Is it possible to use an " if- statement"  in an interrupt service routine ?
Question asked by rschoop on Apr 4, 2010
Latest reply on Apr 23, 2010 by SeanM
Hello all,
I am writing some code to get familiar with VDSP and the  EZ lite board.   Attached you can find a zip file with the project files.
In this  ISR code,   if  I include the  commented out part , the system will halt otherwise it will work fine.  I am testing everything on a oscilloscope.
Is there a problem for using  a n if statement in an  ISR  ??
EX_INTERRUPT_HANDLER(DMA2_ISR)
  *pDMA2_IRQ_STATUS = 0x1;
  b = b + 8;
  b = b % 32;
  if ( b == 24 )
     c = c + 0x00004000;
     c = c % 0x00010000;
  b = b + c;
  *pDMA2_START_ADDR=   b ;
I have another question about the received warnings.  See zip file.    I  realized that I cannot use  pointer arithmetics.
Instead of this code that works fine:
// channel 1
a = CH1_START_ADDRESS;
  ip = a;
  for ( n=0 ;n < 4 ; n++ )
  *ip = buffer1[n];
  a = a + 4;
  ip = a;
  *ip = buffer2[n];
  a = a + 4;
  ip = a ;
I cannot put this code work properly:
// channel 1
  ip = CH1_START_ADDRESS;
  *ip = buffer1[n];
  ip  + =4;
  *ip = buffer2[n];
  ip += 4 ;
Can some explain this a little bit ??
rschoop
