Compiling an ADAU144x project with greater than 100% MIPS
Question asked by BrettG on Mar 16, 2010
Latest reply on Mar 16, 2010 by BrettG
I recently received this question from a customer:
_____________________________________________
We’ve noticed that Sigma Studio will compile without protesting even though MIPS resources might be greater than 100%.
See the attached compiler output file as an example for a program that reports MIPS usage is 106%.
Analog Devices Compiler for the 3rd generation SigmaDSP core.
Build date = 10/20/2009 at 6:27 AM
## Summary ##
Instructions used:
3808    (out of a possible 4096 )
Modulo Data RAM used (X Memory):
1576    (out of a possible 8192 )
Non Modulo Data RAM used (X Memory):
64    (out of a possible 8192 )
Parameter RAM used (Y Memory):
1333    (out of a possible 4096 )
Instance                              Mips    Inst    Data    Coeff    Other
                                          (max)
Total                                  3808    3808    1640    1333
(%)                                      106%    93%    20%    33%
Can we load and run a program that exceeds the MIPS resources or is this to be avoided in all cases?
If it is possible to load and run what side effects should we expect?
