adt1
RTP_RTCP lib rel1.1.0 c++ linker error
Discussion created by adt1 on Mar 10, 2010
Latest reply on Mar 22, 2010 by CraigG
Hi there ,
i encountered problems when compiling with the c++ compiler against the adi_tool_chain.h from the rtp lib. The code from line 293-319:
#if defined _LANGUAGE_C
#ifdef __cplusplus
extern "C" {
#endif /* __cplusplus */
#else /* not _LANGUAGE_C */
#ifdef __cplusplus
#endif /* not _LANGUAGE_C */
encountered. The _LANGUAGE_C macro is defined for both c and c++ compiler. For c++ compiler 'extern "C" {' is used, but the bracket is not closed, because this code is in the not _LANGUAGE_C section.
For this reason the code can be compiled only with the c compiler.
If i change the header files, i can compile it width my c++ code but i get linker error afterwards, although i have added the search path to the librarys:
[Error li1021]  The following symbols referenced in processor 'p0' could not be resolved:
        'adi_rtp_rtcp_Create_1_1(void **, ADI_MEM_MAP *) [_adi_rtp_rtcp_Create_1_1__FPPvP11ADI_MEM_MAP]' referenced from '.\Debug\RtpSrv.doj'
        'adi_rtp_rtcp_Init(void *, ADI_RTP_RTCP_CONFIG *) [_adi_rtp_rtcp_Init__FPvP19ADI_RTP_RTCP_CONFIG]' referenced from '.\Debug\RtpSrv.doj'
Has anyone a idea why the linker does not find the function in the library?
