different blocks containing different data to different DAC's (+DMA)
Question asked by Didier on Mar 10, 2010
Latest reply on Mar 11, 2010 by Didier
Greetings,
For a project I am using a 21369 EZ Lite evaluation board, but I'm having trouble with sending differerent data to different DAC's. I have been using the block-based talkthrough example and modified it here and there for my needs to output a sinewave on DAC4. I used DMA chaining and TCB's for that (removed the one for the ADC, since the blocks were being filled differently) and filled my block with the sinewave values.
Now what I would like to have is to output sinewaves of different frequencies to different DAC's.But I'm a bit confused with the transfer control blocks.
I have created a structure to hold data for let's say 4 different sinewaves in the following way:
typedef struct{
    float ch1[NUM_SAMPLES];          //NUM_SAMPLES = 10
    float ch2[NUM_SAMPLES];
    float ch4[NUM_SAMPLES];
} data;
data block;
I then fill these blocks with my sinewavetable values (1024 samples) using lineair interpolation depending on what frequency I would like to have.
After these blocks are filled I would like to send for instance block.ch1 to the output of DAC1, block.ch2 to DAC2, etc.
The problem is that in the original block-based talkthrough you would have something like:
    //Proceed from Block B to Block c
    TCB_Block_B[0] = (int) TCB_Block_C + 3 - OFFSET + PCI ;
    TCB_Block_B[3] = (unsigned int) Block_B - OFFSET ;
    //Proceed from Block C to Block B
    TCB_Block_C[0] = (int) TCB_Block_B + 3 - OFFSET + PCI ;
    TCB_Block_C[3] = (unsigned int) Block_C - OFFSET ;
and then send C to DAC4:
#ifdef DAC4
    *pSPCTL2 |= (SPTRAN | OPMODE | SLEN24 | SPEN_B | SCHEN_B | SDEN_B) ;
    // write to DAC4
    *pCPSP2B = (unsigned int) TCB_Block_C - OFFSET + 3;
    #endif
and in the main you would select your block with:
unsigned int *src_pointer[2] = {Block_B,
                                             Block_C};
while(1)
     processBlock(src_pointer[int_cntr]);
If possible I would like to know how my TCB's should look like and how many of them I should have.
Because i want to send all blocks at the same time to the DAC's. Do I even need to use chaining at all then?
