How to generate a serial group data?
Question asked by zhu on Jun 16, 2013
Latest reply on Jun 17, 2013 by BrettG
Hello:
One: I use "FilterTableGen" and "Capture" and "Link Complile" to generate a group of EQ(Peaking) data,but
I find some difference between them.
data generated by "Capture" and "Link Complile" is almost same!!!!
frequency=100Hz,Q=0.71
1:/*data generated by FilterTableGen-->Peaking -10dB to 10dB 21 steps 1dB*/
Boost=1
b0=1.00105714797974, 0x00 , 0x80 , 0x22 , 0xA4 ,
b1=-1.98250293731689, 0xFF , 0x02 , 0x3D , 0x58 ,
b2=0.981615662574768, 0x00 , 0x7D , 0xA5 , 0x95 ,
a1=1.98250293731689, 0x00 , 0xFD , 0xC2 , 0xA8 ,
a2=-0.982672810554504, 0xFF , 0x82 , 0x37 , 0xC7 ,
2:/*data generated by Capture Windows Value=1dB*/
EQ1940SingleS10B1         0x0000  0x00,0x80,0x22,0x7F
EQ1940SingleS11B1         0x0001  0xFF,0x02,0x3A,0xF7
EQ1940SingleS12B1         0x0002  0x00,0x7D,0xA8,0x1B
EQ1940SingleS11A1         0x0003  0x00,0xFD,0xC5,0x09
EQ1940SingleS12A1         0x0004  0xFF,0x82,0x35,0x66
3: data generated by Link Complile/* Module Mid EQ1 - Medium Size Eq Value=1dB */
#define MOD_MIDEQ1_COUNT                               5
#define MOD_MIDEQ1_DEVICE                              "IC1"
#define MOD_MIDEQ1_ALG0_STAGE0_B0_ADDR                 0
#define MOD_MIDEQ1_ALG0_STAGE0_B0_FIXPT                0x0080227E
#define MOD_MIDEQ1_ALG0_STAGE0_B0_VALUE                SIGMASTUDIOTYPE_FIXPOINT_CONVERT(1.00105268966457)
#define MOD_MIDEQ1_ALG0_STAGE0_B0_TYPE                 SIGMASTUDIOTYPE_FIXPOINT
#define MOD_MIDEQ1_ALG0_STAGE0_B1_ADDR                 1
#define MOD_MIDEQ1_ALG0_STAGE0_B1_FIXPT                0xFF023AF7
#define MOD_MIDEQ1_ALG0_STAGE0_B1_VALUE                SIGMASTUDIOTYPE_FIXPOINT_CONVERT(-1.98257553578812)
#define MOD_MIDEQ1_ALG0_STAGE0_B1_TYPE                 SIGMASTUDIOTYPE_FIXPOINT
#define MOD_MIDEQ1_ALG0_STAGE0_B2_ADDR                 2
#define MOD_MIDEQ1_ALG0_STAGE0_B2_FIXPT                0x007DA81B
#define MOD_MIDEQ1_ALG0_STAGE0_B2_VALUE                SIGMASTUDIOTYPE_FIXPOINT_CONVERT(0.981692712732305)
#define MOD_MIDEQ1_ALG0_STAGE0_B2_TYPE                 SIGMASTUDIOTYPE_FIXPOINT
#define MOD_MIDEQ1_ALG0_STAGE0_A1_ADDR                 3
#define MOD_MIDEQ1_ALG0_STAGE0_A1_FIXPT                0x00FDC509
#define MOD_MIDEQ1_ALG0_STAGE0_A1_VALUE                SIGMASTUDIOTYPE_FIXPOINT_CONVERT(1.98257553578812)
#define MOD_MIDEQ1_ALG0_STAGE0_A1_TYPE                 SIGMASTUDIOTYPE_FIXPOINT
#define MOD_MIDEQ1_ALG0_STAGE0_A2_ADDR                 4
#define MOD_MIDEQ1_ALG0_STAGE0_A2_FIXPT                0xFF823567
#define MOD_MIDEQ1_ALG0_STAGE0_A2_VALUE                SIGMASTUDIOTYPE_FIXPOINT_CONVERT(-0.982745402396873)
#define MOD_MIDEQ1_ALG0_STAGE0_A2_TYPE                 SIGMASTUDIOTYPE_FIXPOINT
Two: data generated by Capture Windows is douled,for example a "Module Mid EQ1" need 5 32_bits data;
but Capture Windows generated 10 32_bits data.if I use Capture Windows's data,I have to reduce half of
them!Crazing???
But when I design ,I used schematic not "FilterTableGen",I want a way to generate data in the  schematic
Three: "Link Complile" only generated a groud data,if I change value and Link Complile another group
data genterated,but this data
have same name as last. Is there another good way to generate a serial data?
Four: Is there a method to shift phase=Pi/4 from 20Hz to 20KHz?
  Thanks!
             Best regards!
