Writing to SPORT0_TX REGISTER
Question asked by Sid on Feb 19, 2010
Latest reply on Feb 22, 2010 by gvasanth
Hi All,
I am using a custom board consisting of BF533 Blackfin processor Silicon Revision 0.5.
I am trying to implement SPORT UART Interface using SPORT0 without DMA. For basics, I am just trying to send data over DT0PRI to ensure that TX Port is functional. I have initialised SPORT0 and I get valid clock on TSCLK. But when I try to write data to SPORT0_TX register, I see that it fails to get written to the TX register.
Is there anything that I am missing? Is there any anomaly that needs to be implemented?
I am attaching my source code here for reference.
EX_INTERRUPT_HANDLER(SPORT0_ISR);
EX_INTERRUPT_HANDLER(SPORT0_ERROR_ISR);
int main( int argc, char *argv[] )
    //defines
    int a;
    unsigned char uart_sel;
    volatile unsigned short sport0_status;
    volatile unsigned char sport0_rxdata;
    volatile unsigned char sport0_txdata;
    /* Begin adding your custom code here */
    Init_Interrupts();
    SPORT0_initialisation();
    return 0;
void Delay(ULONG n)
    ULONG i;
    for(i = 0;i < n;i++);
void SPORT0_initialisation(void)
    *pPLL_DIV = 0x04;
    *pSPORT0_TCR1 = 0x0000;
    *pSPORT0_TCR2 = 0x0000;
    // TX config
    *pSPORT0_TCLKDIV = 0x1458;        //100000000/2*9600
    *pSPORT0_TFSDIV = 31;
    *pSPORT0_TCR2 = 16;
    *pSPORT0_TCR1 = ITCLK | ITFS | LATFS| TFSR| LTFS;
    ssync();
    *pSPORT0_TCR1 |= TSPEN;        //tx enable
    ssync();
void Init_Interrupts(void)
    // configure interrupt
    *pSIC_IAR0 = *pSIC_IAR0 & 0xffffffff | 0x00000000;    // map SPORT0 Error Interrupt -> IVG7
    *pSIC_IAR1 = *pSIC_IAR1 & 0xffffffff | 0x33322221;    //
    register_handler_ex(ik_ivg7, SPORT0_ERROR_ISR, EX_INT_ENABLE);
    register_handler_ex(ik_ivg9, SPORT0_ISR, EX_INT_ENABLE);
      *pSIC_IMASK = SPORT0_ERR_IRQ | DMA2_IRQ;
    ssync();
}//end Init_Interrupts
    int i;
    unsigned short statreg=0;
      *pDMA2_IRQ_STATUS = 0x1;
    ssync();
    while ((*pSPORT0_STAT & TXF)==1);
    *pSPORT0_TX = (unsigned short)0xCC0A;
    ssync();
    while ((*pSPORT0_STAT & TXHRE)==0);
    *pSPORT0_TX = (unsigned short)0x8061;
    ssync();
    while ((*pSPORT0_STAT & 0x0040) == 0)        // While HOLD not empty....
    {asm("nop;");};
    for(i=0;i<0x40000;i++)
    {asm("nop;");};
    *pSPORT0_TCR1 &= ~0x0001;                    // Disable Transmit INT
    unsigned short status;
    status = *pSPORT0_STAT;
    if (status & TUVF){ //W1C
        *pSPORT0_STAT = status | TUVF;
        ssync();
        txUnderflowStatus++;
        ssync();
    if (status & TOVF){ //W1C
        *pSPORT1_STAT = status | TOVF;
        ssync();
        txOverflowStatus++;
        ssync();
    if (status & TXHRE){ //
        txHoldRegEmpty++;
        ssync();
    if (status & TXF){ //
        txFifoFull++;
        ssync();
Thanks and Regards,
Sid
