michaelc21
Re: EQ Algorithm, Low  shelf wrong!
Discussion created by michaelc21 on Jan 28, 2010
Latest reply on Feb 4, 2010 by sanjaac
Branched from an earlier discussion
Thank you for all  your answer.
These days I go back to the  ADI dsp project again.
I use the calculate  coefficent method.
Good news is that,  I am right  to calculate  the  PEQ's  coefficent.
A  = 10^(boost/40)
ω0 = 2*pi*f0/Fs
alpha = sin(ω0)/(2*Q) (type: Peaking)
      = sin(ω0)/2 * sqrt((A + 1/A)*(1/S - 1) + 2) (type: Shelving)
gainLinear = 10^(gain/20)
a0 =  1 + alpha/A
a1 = -2 * cos(ω0)
a2 =  1 - alpha/A
b0 = (1 + alpha*A) * gainLinear
b1 = -(2 * cos(ω0)) * gainLinear
b2 = (1 - alpha*A) * gainLinear
But the  Low shelf  and  Hight shelf  doesn't  right.
For Low shelf , I use  these  formulas:
alpha = sin(ω0)/2 * sqrt((A + 1/A)*(1/S - 1) + 2) (type: Shelving)
a0 = (A+1) + (A-1)*cos(ω0) + 2*sqrt(A)*alpha
a1 = -2*( (A-1) + (A+1)*cos(ω0) )
a2 = (A+1) + (A-1)*cos(ω0) - 2*sqrt(A)*alpha
b0 =  A*( (A+1) - (A-1)*cos(ω0) + 2*sqrt(A)*alpha ) * gainLinear
b1 =  2*A*( (A-1) - (A+1)*cos(ω0) ) * gainLinear
b2 =  A*( (A+1) - (A-1)*cos(ω0) - 2*sqrt(A)*alpha ) * gainLinear
When calculate the "alpha", I see there is an 'S', I thought it is shelf "slope", right?
Then , I use the formula above the calculate the 5 coeffient, but it is much defferent from
what I saw in the capture window.
I use vc++6.0 to test all the calculating, the appatch is the code file,and project of Sigma .
Urgency!
Thank you!
