Does the function "fread" have a upper-limit size for SHARC 21369?
Question asked by gggboy on Jan 26, 2010
Latest reply on Jan 29, 2010 by Mitesh
I allocated a memory of N*32 bits in external memory successfully. When I tried to use "fread" function to read data from file on PC to the memory I allocated, I found it has a upper-limit size of 20*1024*32 bits.
If N is less than that size, it can read successfully. If N is more than that size, the function will jump to somewhere it was not supposed to.
So, does the function "fread" have a upper-limit size? How can I enlarge the upper-limit size?
code segment:
#define FILE_BUF_SIZE    1024*20
//allocate 4 memory segment.
    inPcmData_L_R = (int*)malloc(sizeof(int)*FILE_BUF_SIZE);
    inPcmData_SL_SR = (int*)malloc(sizeof(int)*FILE_BUF_SIZE);
    inPcmData_C_S = (int*)malloc(sizeof(int)*FILE_BUF_SIZE);
    inPcmData_SC = (int*)malloc(sizeof(int)*FILE_BUF_SIZE);
    outPcmData = (int*)malloc(sizeof(int)*FILE_BUF_SIZE);
//read 4 files to the allocated memory
static void InitPcmIO()
    pcmOut = fopen(outFileName,"wb");
    pcmIn_L_R = fopen(inFileName_L_R, "rb");
    pcmIn_SL_SR = fopen(inFileName_SL_SR, "rb");
    pcmIn_C_S = fopen(inFileName_C_S, "rb");
    pcmIn_SC = fopen(inFileName_SC, "rb");
