Delay Line in External Memory
Question asked by MarcS. on Jan 21, 2010
Latest reply on Feb 17, 2010 by Mitesh
I'm using the ADSP-21469 EZ-Board and I would like to use the 128Mb external DDR2 SDRAM for storing 8 delay lines (1 per output channel). I don't want to use DMA for data transport between external memory and core processor because of a sample-based processing.
At the moment I use the following algorithm for the delay line:
    Channel_Out = Delayline[Index];
    Delayline[Index++] = Channel_In;
    if (Index == DELAYLINE_LENGTH) {Index = 0;}
The variables Channel_Out and Channel_In are located in internal memory. If the delay line is located in internal memory too, everything works fine.
To store the delay in external memory I declared it in the following way:
section ("seg_ext_dmda") float Delayline[DELAYLINE_LENGTH];
Furthermore I have added this to the ldf-file:
MEMORY:
seg_ext_dmda  { TYPE(DM RAM) START(0x00900000) END(0x01DFFFFD) WIDTH(16) }
SECTIONS:
        seg_ext_dmda
            INPUT_SECTIONS($OBJECTS(seg_ext_dmda) $LIBRARIES(seg_ext_dmda))
        } > seg_ext_dmda
In this case I receive a signal at the output, but not the one I have expected.
Figure #1 shows the input (blue) and the expected output (red) without delay in this case.
Figure #2 shows the input (blue) and the received output (red) with delay in this case.
Perhaps someone has a hint what I have consider using the external memory.
Marc
