Loading code into internal and external memory on Ez-Kits
Question asked by MikeSmithCanada on Jan 12, 2010
Latest reply on Jan 12, 2010 by CraigG
Hi
With Blackfin 533 eval board -- if you get VDSP complaints that your code does not map into memory (i.e. internnal memory) you can go and change the VDSP linker settings to "use internal memory and external SDRAM" -- neat and easy to use default fix for this sort of problem
I am trying to port the same testing framework to TigerSHARC TS201 and SHARC 21469 eval boards -- and the full test of the framework will not fit into the memory using the standard LDF -- I can't find the equivalent VDSP setting  "use internal memory and external SDRAM" -- am I looking in the wrong place (can't see the wood for the trees) and this setting exists, or do I have to go in and change the LDF by hand?  -- I've never mastered the expert linker tool
If not available -- could you add this "neat and easy to use default fix for this sort of problem" to my wish list for next release
Thanks
