ADAU1761 PLL lock
Question asked by farhad20 on Dec 10, 2009
Latest reply on Dec 10, 2009 by JeradL
Hello
I am not able to see Lock bit in  PLL control register (ox4002)  changes from 0=>1 during initilization of ADU1761.
If I skip checking this flag it seems DSP is running fine.
Here is my code:
void Init_ADAU1761(void) //to test by-pass DSP
ADAU1761_pll_locked=0;
  ADAU1761_SAMPLERATE_SET_REG(0x7f); //ok
  ADAU1761_DSP_RUN_REG (0x00); //0k
  ADAU1761_CLOCK_CONTROL_REG (0x0f);//ok
  ADAU1761_PLL_CONTROL_REG(0x00,0xfd,0x00,0x00,0x20,0x03); ///<<--???
  ADU1761_SERIALPORT_CONTROL(0x00, 0x00);
  ADAU1761_ALC_CONTROL_REG (0x00,0x00,0x00,0x00);
  ADAU1761_MIC_CONTROL_REG(0x00);
   ADAU1761_RECORD_IN_SIG_PATH_REG    (  0x00, 0x51, 0x00, 0x51,
                                        0x00, 0x44, 0x5e, 0x00 );
  ADAU1761_ADC_CONTROL_REG           (  0x33, 0x00, 0x00); //<- 20 Nov 2009 changed to turn on HP of ADC  (0x13,0x00,0x00);
  ADAU1761_PLAYBACK_OUT_SIG_PATH_REG (  0x21, 0x00, 0x41, 0x00,
                                        0x03, 0x09, 0x01, 0x01,
                                        0x01, 0xfe, 0xfe, 0x01,
                                        0x00, 0x03);
  ADAU1761_CONVERTER_CONTROL_REG(0x00,0x00);
  ADAU1761_DAC_CONTROL_REG(0x07,0x00,0x00); //enable DAC de-emphasis (0x03,0x00,0x00);
  ADU1761_SERIALPORT_PAD_CONTROL(0xaa);
  ADU1761_COMMPORT_PAD_CONTROL (0xaa,0x00);
  ADAU1761_MCLK_JACKDET_PAD_CONTROL_REG(0x0a);
  ADAU1761_DSP_ON_REG(0x01);
  ADAU1761_CRC_REG(0x00,0x00,0x00,0x00,0x01);
  ADAU1761_GPIO_REG(0x00,0x00,0x00,0x00);
// ADAU1761_NON_MODULO_REG(0x0f,0xfe);
  ADAU1761_WATCHDOG_REG(0x01,0x00,0x00,0x00,0x00);
  ADAU1761_ROUTING_MATRIX_IN_REG(0x00);
  ADAU1761_ROUTING_MATRIX_OUT_REG(0x00);
  ADAU1761_SERIAL_DATA_CONFIG_REG(0x00);
  ADAU1761_DSP_SLEW_MODE_REG(0x00);
  ADAU1761_SERIAL_PORT_SAMPLERATE_REG(0x00);
ADAU1761_CLOCK_ENABLE_REG(0x7f,0x03);
  ADAU1761_PROGRAM_DATA_WRITE(); // <- note debug it!!
  ADAU1761_PARAM_DATA_WRITE(); // <-note debug it!!
// ADAU1761_NON_MODULO_RAM();
//ADAU1761_PLL_CONTROL_REG() //READ REQUEST
  //ADAU1761_DSP_ON_REG(0x01);
while ( ADAU1761_pll_locked == 0x00 )  //  interrupt ISR updates this flag                                       {
                                        Delay_100();//  for (i=0 ;i<10 ;i++) {for (j=0; j<10 ;j++) {} }
                                        ADAU1761_PLL_Control_Read();
  ADAU1761_DSP_RUN_REG(0x01);
  ADAU1761_SAMPLERATE_SET_REG(0x01);
