BF537 Ethernet TXDma Channel Error
Question asked by pfeifferc on Oct 29, 2009
Latest reply on Nov 11, 2009 by jobo23
i have troubles to acknowledge a DMA_Err caused by a EthernetTX transmission.
i use following code derived from original ADI_ETHER_BF537
// ensure a 32 bit access to the MMRs is issued before the 16 bit access in case
// the interrupt killed a 32 bit access - anomaly ED(03-00-0048)
addr = dev->Tx.Dma->START_ADDR;
// check our two DMA channels
if (*pDMA2_IRQ_STATUS&0x02)  /*this is the TX int*/
  {  // error on TX channel
  result = ADI_INT_RESULT_PROCESSED;
  // acknowedge the interrupt
*pDMA2_CONFIG &= ~DMAEN;
  *pDMA2_IRQ_STATUS = 0x02;
  /*dev->Tx.Dma->IRQ_STATUS = 0x02;*/
without the red marked line i'm not able to clear the DMA_ERR bit, so i added this one.
( IRQ_status contains 0x03 in my error case)
is this a must or is there any other solution requested?
regards chris
