AD9911 SPI Programming
Question asked by angrygrape on Jun 7, 2013
Latest reply on Jun 30, 2013 by angrygrape
I use PIC18LF4520 to configure registers in AD9911. My reference clock is 100MHz and I can get an 25MHz at Pin54(SYNC_CLK). However, I cannot get any signal at outp pins. I will attach the schematic and  C program. Any hint will be appreciated!
#pragma config OSC=HS
#pragma config PWRT=ON, BOREN=OFF
#pragma config WDT=OFF
#pragma config LVP=OFF //configuration bits setting
#include<p18cxxx.h>
#include<spi.h>
#include<delays.h>
#define uchar unsigned char
#define MRESET LATCbits.LATC1 //AD9911 master reset outpout, PORTC pin1
#define SYNC LATCbits.LATC2 //AD9911 SYNC_IO function output, PORTC pin2
#define SCK LATCbits.LATC3 //Serial CLK
#define SDO LATCbits.LATC5 //Serial Data Output
#define CSN LATDbits.LATD4 //CSN output pin, PORTD pin4
#define UPDATE LATDbits.LATD5 //AD9911 IO_UPDATE function output, PORTD pin5
#define PRO LATDbits.LATD6 //AD9911 Profile Pin1, PORTD pin6
void Initial(void);
void SPIiniti(void); //function prototypes
void main()
    Initial();
    SPIiniti();
    CSN=0; //CSN Low
    Delay100TCYx(50); //a delay in 2ms
          WriteSPI(0b00000000); //instruction byte, write operation, CSR
          WriteSPI(0b00100010); //Phase 2 of IO cycle, disable CH3\CH2\CH0,
    //enable CH1, bit3 must be 0, single bit serial(3-wire mode), MSB first
          WriteSPI(0b00000100); //CTW0 is accessed during phase 2, 4 bytes wide
    WriteSPI(0b00100000); //12.5MHz is expected, FTW, bits<31:24>
          WriteSPI(0b00000000); //bits<23:16>
    WriteSPI(0b00000000); //bits<15:8>
    WriteSPI(0b00000000); //bits<7:0>
    CSN=1; //CSN High
    UPDATE=1; //IO_UPDATE High, a rising edge triggers data transfer from the
    //IO port buffer to active registers
    Delay10TCYx(10); //a delay in 40us
    UPDATE=0; //IO_UPDATE Low
    while(1);
void Initial()
    INTCON=0x00;
    PIE1=0x00;
    PIE2=0x00;
          TRISCbits.TRISC1=0; //RESET output
    TRISCbits.TRISC2=0; //SYNC_IO output
          TRISCbits.TRISC3=0; //SCK output
          TRISCbits.TRISC5=0; //SDO output
    TRISDbits.TRISD4=0; //CSN output
    TRISDbits.TRISD5=0; //IO_UPDATE output
    TRISDbits.TRISD6=0; //Profile Pin1 output
    MRESET=1; //Issue a Master Reset
    MRESET=0; //Master Reset Low
          CSN=1; //CSN High
          SCK=0; //SCK Low
          SDO=0; //SDO Low
    SYNC=0; //SYNC_IO Low
    PRO=0; //Profile Pin1 Low
void SPIiniti()
    OpenSPI(SPI_FOSC_64,MODE_01,SMPEND);
