Detecting a Rising Edge - SHARC Assembly
Question asked by cconrad on Jun 7, 2013
Latest reply on Jun 17, 2013 by Harshit.Gaharwar
Greetings,
I'm trying to block until the rising edge of a Flag pin (Low to High), which is driven by a PCG timer square wave.  This code works fine:
flg_high:  BIT TST FLAGS FLG10;
           IF TF JUMP flg_high;
flg_low:   BIT TST FLAGS FLG10;
           IF NOT TF JUMP flg_low;
except there is cycle jitter associated with it.  Since it's a two cycle test, depending on where the CPU is in relation to the edge
you will get a 1 or 2 core cycle delay coming off the edge.
I'm trying to tighten this up this loop by using the zero overhead looping:
DO flg_high UNTIL TF;
DO flg_low  UNTIL NOT TF;
Now my jitter does go away, however this loop seems to be detecting High to Low to High, instead of just
Low to High.  That is, depending on how late I start this in the cycle it will count every cycle, or every other cycle.
I'm sure there is something I'm not understanding about the sequencer, test, and cache.  Can someone enlighten me?  Thanks,
PMT
