ADV7511 with HDCP enabled gives "Ri mismatch" on some reveivers
Question asked by WolfgangZ on Jun 6, 2013
Latest reply on Jun 7, 2013 by DaveD
I have a company-designed board with a 7511 HDMI-Tx which works well without HDCP enabled.
When HDCP is enabled, some connected devices don't get a stable HDCP encryption.
In these cases the BKSV-interrupt comes first after a couple of seconds.
Then the DDC-state shows shortly "HDCP enabled". But after about a second the state changed to
"Initalizing HDCP" and the DDC-Errorcode changed to "Ri Mismatch".
After this the state toggles sporadically between enabled and initializing.
I have already checked all Sync-inputs for glitches - none found.
Also I set the bit for internal EPROM and tested many different delay values in the registers
0xFC to 0xFE without success.
This is the list of tested HDMI receivers:
Device                HDCP-ok   measured DDC-pollrate
Quantum 780              no           96 - 148 ms
Sony KDL H40 LCD-TV      no
Tektronix WFM 5250       yes          315 ms
Board with Adv7612       yes          320 ms
Samsung Syncmaster P2470 yes          2500 ms
What can I do to make our 7511-board compatible to all HDMI receivers?
Wolfgang
