Error li1050 CCES 1.0.2.0
Question asked by bookevg on Jun 5, 2013
Latest reply on Jun 6, 2013 by ColinJ
I try to export the project from http://ez.analog.com/thread/19118 to my workspace. CCES 1.0.1.1 work good. CCES 1.0.2.0 work bad.
When I do import I get the window:
"The IDE has detected that the Startup Code/LDF template have changed. Would you to regenerate the Startup Code/LDF files used in project shadow".
If I select the button "Yes" the window appear again and again.
If I put the button "No" and I do Project-Clean and Project-Build Project I get Error li1050 like:
[Error li1050]  '_heap_table' ('heap_table'): Multiply defined symbol in processor 'p0'.
        Initial definition:     '.\system\startup_ldf\app_heaptab.doj'
        Attempted redefinition: '.\shadow\system\startup_ldf\app_heaptab.doj'
If I try to use "system.svc" and select Startup Code/LDF the window appear again. If I select the button "Yes" the window appear again and again.
