u-boot access
Question asked by h-endou on Jun 4, 2013
Latest reply on Jun 4, 2013 by Aaronwu
Hi, Software enginner
I have a question about u-boot access.
When u-boot accesses a Flash device,
The internal function(1) which is called from SPI common function(2)
seems to check whether if there is "Ctrl+C".
When the function(1) detected "Ctrl+C" input, SPI access processing seems to stop
processing. Is this intended processing?
If it is the processing intended, what kind of thing is this processing assume?
  • Driver for Blackfin On-Chip SPI device
  • Copyright (c) 2005-2010 Analog Devices Inc.
  • Licensed under the GPL-2 or later.
"Ctrl+C" is called ('**'mark below)
static int spi_pio_xfer(struct bfin_spi_slave *bss, const u8 *tx, u8 *rx,
   uint bytes)
/* discard invalid data and clear RXS */  read_SPI_RDBR(bss);
/* todo: take advantage of hardware fifos  */  while (bytes--) {
  u8 value = (tx ? *tx++ : CONFIG_BFIN_SPI_IDLE_VAL);
  debug("%s: tx:%x ", __func__, value);
  write_SPI_TDBR(bss, value);
  SSYNC();
  while ((read_SPI_STAT(bss) & TXS))
**if (ctrlc())
    return -1;
  while (!(read_SPI_STAT(bss) & SPIF))
**if (ctrlc())
    return -1;
  while (!(read_SPI_STAT(bss) & RXS))
**if (ctrlc())
    return -1;
  value = read_SPI_RDBR(bss);
  if (rx)
   *rx++ = value;
  debug("rx:%x\n", value);
return 0;
Best Regards,
Endo
