AD9914 Eval Board: DAC Cal and PLL Cal
Question asked by tnagy14 on Jun 2, 2013
Latest reply on Jun 2, 2013 by LouijieC
I am using the AD9914 Eval board with SPI communication to an Arduino.  Can someone confirm the correct or best way to issue the DAC CAL and PLL CAL.  I have tried both of the following and do not see any difference in the output quality, is either correct? I also have tried no calibration at all and still the get same output (which looks stable).  How can I confirm the calibration was done successfully?
The difference between the two options is simply when to pulse IO_UPDATE.  Is it required to do it between the two writes to CR 4?
1st:
write     0x01010002   //CR 1, PLL Cal bit 24 HIGH
Write    0x00800000   //CR 2
Write    0x00040C1C  //CR 3
Write    0x01052120   //CR 4, DAC CAL bit HIGH
Write    0x00052120   //CR 4, DAC CAL bit LOW
Write    Frequency Tuning Word
Pulse IO_UPDATE
2nd:
pulse IO_UPDATE
Pulse IO_UPDATE
Thanks
