Access variable outside interrupt
Question asked by NTan on Jun 2, 2013
Latest reply on Jun 10, 2013 by CraigG
Good Day Everyone!
     I'm using a BF537 EZ Kit Lite and Visual DSP ++ 5.0, Update 10.1. I have an UART RX interrupt which stores the data in UartRcvBuff. It is declared as char UartRcvBuf[STRINGSIZE]; in my uart.c file. However, I would like to access the value of UartRcvBuff in my main function (found in main.c). I've tried initializing it as volatile char UartRcvBuf[STRINGSIZE], but it still doesn't work.
     May I have any suggestions on how I may access a variable outside an interrupt? Below are the snippets of the code. (I've removed some code so it would be easier to understand).
===== UART.C FILE =====
char rcvbuf[STRINGSIZE];
EX_INTERRUPT_HANDLER(UartInterruptsHandlerData)
          /* some code here */
         if (*pUartLsr & DR) {
                   UartGets(UartNum, rcvbuf);
===== MAIN.C FILE =====
int main(void)
    while(*pIMASK & 0x4000 && check < 30 ) {  //Sends A 30 times and stops when interrupt in rx pin is disabled
                   UartPutc(0, 'A');
          check ++;
    if (rcvbuf[0] == 'B'){
           printf("success");
          return 0;
     else{
          /*some code here*/
Thank you and any suggestion would be appreciated
Nicole
