Interfacing ultrasonic sensor with ADUC7060 eval board
Question asked by Azrine on May 26, 2013
Latest reply on May 27, 2013 by ABuda
I am trying to interface a sensor(40 KHz operation) to the Eval board and we are using the following code. The code consists of accepting two low to high pulses from the sensor and finding the time difference between the two pulses and output the result in UART. We are unable to send the output on UART. The code is as follows:
#define BIT0  0x01
#define BIT1  0x02
#define BIT2  0x04
#define BIT3  0x08
#define BIT4  0x10
#define BIT5  0x20
#define BIT6  0x40
#define BIT7  0x80
#define BIT8  0x100
#define BIT9  0x200
#define BIT10 0x400
#define BIT11 0x800
#define BIT12 0x1000
#define BIT13 0x2000
#define BIT14 0x4000
#define BIT15 0x8000
#define BIT16 0x10000
#define BIT17 0x20000
#define BIT18 0x40000
#define BIT20 0x100000
#define BIT24 0x1000000
#define TIMER_LD 0x10000
void ConfigurePWM(void);
#include<aduc7060.h>
void SendHexASCII(unsigned long Value, unsigned char Digits);
void SendChar(char Character);
char Hex2Ascii(char toconv);
unsigned int Timer_R_Count, Timer_F_Count, Timer_Diff;
unsigned char bTripDetected = 0;
int main(void)
          GP1CON  = 0x00000011;                                                     // Select UART functionality for P1.0/P1.1
          COMCON0 = 0x80;        // Enable access to COMDIV registers
          COMDIV0 = 0x21;        // Set baud rate to 9600.
          COMDIV1 = 0x00;
          COMCON0 = 0x07;
          POWKEY1 = 0x1;
          POWCON0 = 0x78;                       // Set core to max CPU speed of 10.24Mhz
          POWKEY2 = 0xF4;
          // Initialize the GPIO pins for PWM mode
          GP0CON0  = 0x00000000;
          GP1CON  = BIT8 | BIT12 | BIT16 | BIT20;            // Select PWMSYNC and PWMTRIP functions
                                        // Select PWM2, PWM3 output
          GP0DAT   = 0x0F000000;                                                            // Select GP0.0 to GP0.3 as output all 4 OFF
          GP2CON   = 0x00000000;                                                            // P2.0 = GPIO & IRQ2
          IRQCONE  = 0x00000022;                                                            // IRQ0 & IRQ2 rising edge
          T0LD     = TIMER_LD;                                                            // Set Timer 0 Value
        // Value to be selected for Error-Handling
        // if no pulse is detected
          T0CON    = 0x00030480;                                                            // Enable Timer 0 count down @ 10.24MHz
        // with Capture on rising edge from external IRQ2
          PWMCON          = BIT0 + BIT10;           // PWM Standard mode, UCLK/2, PWM Trip interrupt enabled
          ConfigurePWM();                              // Call function to configure PWM
          bTripDetected = 0;
          IRQEN          = BIT17+BIT18+BIT3+BIT13;                     // Enable PWM Trip interrupt source
             if (bTripDetected == 1)
                                 bTripDetected = 0;
                                 ConfigurePWM();
                                 while (1)
          // Endless Main Loop - to send out data on UART
                    SendChar('\r');
                    SendHexASCII(T0VAL, 8);
                    SendChar(' ');
                    SendHexASCII(Timer_R_Count, 8);
                    SendChar(' ');
                    SendHexASCII(Timer_F_Count, 8);
                    SendChar(' ');
                    SendHexASCII(Timer_Diff, 8);
                    SendChar(' ');
// IRQ Handler for Timer Capture of PWM-Pulse
void IRQ_Handler(void) __irq
// no need to buffer IRQSTA - the events can't be lost
       unsigned long IRQSTATUS = 0;
          IRQSTATUS = IRQSTA;             // Read off IRQSTA register
          if ((IRQSTATUS & BIT17) == BIT17)          //If PWM trip interrupt source
                     bTripDetected = 1;                    // Set flag to re configure the PWM block
                     PWMCLRI = 0xFF;                    // Clear the PWM trip interrupt source
          if(IRQSTA == 0x00040000)                                                  // IRQ2 == rising edge of signal
          {        // YES !
                    GP0SET = 0x00010000;
                    Timer_R_Count = T0CAP;                                                  // read back captured rising count
                    IRQCLRE = 0x00040000;                                                  // Clear IRQ 2 Interrupt
                    T0CON  = 0x0002B480;                                                  // Enable Timer 0 count down @ 10.24MHz
                    GP0CLR = 0x00010000;
          else if(IRQSTA == 0x00002000)                                        // IRQ0 == falling edge of signal (rising edge on IRQ0)
          {        // falling edge triggered !
                    GP0SET = 0x00020000;
                    Timer_F_Count = T0CAP;                                                  // read back captured falling count
        // calculate pulse length
        // !!! Timer0 is counting down !!!
                    Timer_Diff = Timer_R_Count - Timer_F_Count;
                    IRQCLRE  = 0x00002000;                                                  // Clear IRQ 0 Interrupt
                    T0LD     = TIMER_LD;                                                  // Set counter to prevent Error underflow
        // with Capture on rising edge from external IRQ0
                    GP0CLR  = 0x00020000;
          else if(IRQSTA == 0x00000008)                                        // Timer 0 overflow - no valid pulse
                    T0CLRI = 0x00;        // Clear Timer 0 Overflow Interrupt
                    Timer_Diff = Timer_F_Count = Timer_R_Count = 0xEEEEEEEE;
          //Configure PWM2 for 100khz duty cycle
          // P1.5
          PWM1COM0 = 0x62;                    //          Configure PWM2 output high trigger time
          PWM1COM1 = 0x31;                    //          Configure PWM2 output Low trigger time
          PWM1COM2 = 0x62;                    //          Configure PWM3 output low trigger time
          PWM1LEN = 0x31;                    //          Configure PWM3 output high trigger time
// Send a Integer as HEX-ASCII characters
          while(Digits != 0)
                    SendChar(Hex2Ascii((Value >> (--Digits * 4) & 0x0F)));
// Send a Character to UART
                    while(!(0x020==(COMSTA0 & 0x020))){}
                      COMTX = Character;
// HEX-ASCII conversion
          if (toconv<0x0A)
                    toconv += 0x30;
          else
                    toconv += 0x37;
          return (toconv);
