Pwm control
Question asked by binki on May 26, 2013
Latest reply on May 27, 2013 by binki
Hi Nabeel,
I am assuming few things regarding Pwm. Can you please correct me if I am wrong.
Suppose if I have configured 8 channels.
i.e PWM0_AH to PWM0_DL
And by configuring following parameters:
        0x0,                                                    /* Dead Time between high and low Pwm channels */
    PWMTMR0_SYNC,                                   /*PWM sync timer mode select */
    PWM_SYNCHRONOUS,                          /*PWM Sync/Async select */
    PWM_INTERNAL_SYNC,                         /*PWM Int/Ext select */
        0x3ff,                                                        /* Sync width pulses */
    PWM_CHOP_DISABLE,                      /*PWM Chop Enable/Disable*/
        0x0,                                              /* Chop frequency for gate drive circuits */
                TRUE,                                  /* Pwm Trip Enable/Disable */
              PWM_TRIP0_SRC,                                        /* TRIP0 or TRIP1 source selection */
    PWM_FAULT_TRIP,                                  /*PWM Trip mode select */
    PWM_HARDWARE_TRIP                         /*PWM Trip select */
Will these parameters  be common to all channels configured or can we have separate configuring of these parameters to individual channels?
i.e Can we have dead time separately for PWM_AH and PWM_AL, or will it be same for all channels if configured once in PWM_DT register.
Kishore K
