BF518 OTP Memory Write Error(s).
Question asked by alemannia on May 24, 2013
Latest reply on Jul 27, 2013 by alemannia
I am writing data (MAC address) into a page of the OTP memory. The data gets written correctly, but I often get the error codes:
ret = 0x021 ( OTP_MASTER_ERROR | OTP_ECC_MULT_ERROR )
ret = 0x200 ( OTP_ECC_SB_WARN )
When I then read the written page, the content is always OK. It's the ECC that's obviously messed up. Any idea why this would happen? I have stable 7V applied when writing the data.
I initialize the OTP once at system startup:
/* Initialize OTP timings. */
#define SYS_SCLK_MHZ     133
#define OTP_TIMING      ( 0x14548700 | ( SYS_SCLK_MHZ ) )
bfrom_OtpCommand( OTP_INIT, OTP_TIMING );
Here is my write routine:
unsigned int _write( uint_t page, const uint8_t data[DRV_OTP_PAGE_SIZE] )
  uint32_t ret;
  uint32_t flags;
  uint64_t lower;
  uint64_t upper;
  memcpy( &lower, &data[0], DRV_OTP_PAGE_SIZE/2 );
  memcpy( &upper, &data[8], DRV_OTP_PAGE_SIZE/2 );
  /* Write lower half page. */
  flags = OTP_LOWER_HALF | OTP_CHECK_FOR_PREV_WRITE;
  ret = bfrom_OtpWrite( page, flags, &lower );
  if( ret ) {
    return ret;
  /* Write uppper half page and lock page. */
  flags = OTP_UPPER_HALF | OTP_CHECK_FOR_PREV_WRITE | OTP_LOCK;
  ret = bfrom_OtpWrite( page, flags, &upper );
  if( ret ) {
    return ret;
  return 0;
Cheers!
