AD9910 Eval Board Sys_clk setup and sync_clk output
Question asked by harrycheung on May 22, 2013
Latest reply on May 23, 2013 by Kevin.G
Hi all,
I have been testing the Evaluation Board and is designing a new PCB for AD9910. I am trying to reproduce results of my custom board on the Eval Board. First, I want to set up the system clock. I power up the Eval Board, then connect a 100MHz 2V Vpp sine wave into the ref_clk, then I connect it with the computer with the software but I have not yet select the board on the software. I can see a 12.5 MHz, 1.6Vpp square wave on sync_clk, which is expected.
Then I do this again but without connecting to the computer. I power up the DDS and put in a 100MHz ref_clk. Then I connect the master_reset to logic high (3.3V) and then remove the connection. However, the sync_clk output is still zero.
My question is
How should I set up the system clock given that I have connected the ref_clk to a 100MHz signal? Is changing the master reset pin enough?
and
Do I need to do anything to see the f_sysclk/4 signal at the sync_clk output?
Thanks
