Using UART3 on the ADSP BF548 EZ-KIT LITE REV 1.4 with Interrupt using System Services
Question asked by sujan5614 on May 21, 2013
Latest reply on Jul 16, 2013 by sujan5614
         I am trying to run UART3 on BF548 EZ-KIT, using Interrupt. I used the reference code of UARTEcho.c that came with VisualDSP++ installation. I have connected UART1, and it is running successfully.
Initially I was facing problem with UART3 since there was no DMA mapped to UART3 by default.
I took help of the forums and now i have successfully mapped ADI_DMA_DMA20 to ADI_DMA_PMAP_UART3_RX and ADI_DMA_DMA21 to ADI_DMA_PMAP_UART3_TX using adi_dma_SetMapping().
But now my code gets stuck in adi_dev_Control() where it updates the UARTConfiguration Table. My code gets stuck in the "Enable Error Reporting" part where it is unable to set the interrupt settings and goes on a loop.
I have compared the code, for UART1 and UART3 (changing the #define UART_DEVICE_NUMBER), and the code is working fine for UART1.
I have disabled Deferred Callbacks.
So, is there anything extra that I need to change for using UART3??
Below is the part of the changes made for DMA mapping ::
if ((pDevice->Direction == ADI_DEV_DIRECTION_INBOUND) || (pDevice->Direction == ADI_DEV_DIRECTION_BIDIRECTIONAL)) {
                     if(adi_dma_SetMapping(pDevice->InboundPMAP, ADI_DMA_DMA20) != ADI_DMA_RESULT_SUCCESS)
                                   printf("Failed to set DMA mapping \n");
                                   break;
           else
                      printf("set DMA mapping successfully for ADI_DMA_PMAP_UART3_RX\n");
          if (adi_dma_GetMapping(pDevice->InboundPMAP, &DMAChannelID) != ADI_DMA_RESULT_SUCCESS) {
                Result = ADI_UART_RESULT_NOT_MAPPED_TO_DMA_CHANNEL;
                break;
if ((pDevice->Direction == ADI_DEV_DIRECTION_OUTBOUND) || (pDevice->Direction == ADI_DEV_DIRECTION_BIDIRECTIONAL)) {
           if(adi_dma_SetMapping(pDevice->OutboundPMAP, ADI_DMA_DMA21) != ADI_DMA_RESULT_SUCCESS)
                          break;
           else
           printf("set DMA mapping successfully for ADI_DMA_PMAP_UART3_TX\n");
                   if (adi_dma_GetMapping(pDevice->OutboundPMAP, &DMAChannelID) != ADI_DMA_RESULT_SUCCESS) {
                break;
Thanks
Sujan.
Message was edited by: Sujan Nag
