ADV7611 free run not working
Question asked by phight on May 18, 2013
Latest reply on May 22, 2013 by phight
There are two adv7611 chips in the same i2c bus, one's VS/FIELD/ALSB pin is pull up (can't access with address 0x9A), the other one is float(can access with 0x98), the XTAL is 27M.
I want to support different input resolution, and output 16 bit BT.656 YCrCb422,(I only use the low 16 data pin, P[15:8]Y, P[7:0]CrCb).
I used the following two settings,  but they all didn't work.   (the test input resolution is 1080p30)
98 FF 80 ; I2C reset
98 F4 80 ; CEC
98 F5 7C ; INFOFRAME
98 F8 4C ; DPLL
98 F9 64 ; KSV
98 FA 6C ; EDID
98 FB 68 ; HDMI
98 FD 44 ; CP
98 01 26 ; Prim_Mode =110b HDMI-GR
98 02 F5 ; Auto CSC, YCrCb out, Set op_656 bit
98 03 80 ; 16 bit SDR  BT656 422 Mode 0
98 04 60 ; 27M
98 05 28 ; AV Codes Off
98 06 A6 ; Invert VS,HS pins
98 0B 44 ; Power up part
98 0C 42 ; Power up part
98 14 7F ; Max Drive Strength
98 15 80 ; Disable Tristate of Pins
98 19 83 ; LLC DLL phase
98 33 40 ; LLC DLL enable
44 BA 01 ; Set HDMI FreeRun
64 40 81 ; Disable HDCP 1.1 features
68 9B 03 ; ADI recommended setting
68 C1 01 ; ADI recommended setting
68 C2 01 ; ADI recommended setting
68 C3 01 ; ADI recommended setting
68 C4 01 ; ADI recommended setting
68 C5 01 ; ADI recommended setting
68 C6 01 ; ADI recommended setting
68 C7 01 ; ADI recommended setting
68 C8 01 ; ADI recommended setting
68 C9 01 ; ADI recommended setting
68 CA 01 ; ADI recommended setting
68 CB 01 ; ADI recommended setting
68 CC 01 ; ADI recommended setting
68 00 00 ; Set HDMI Input Port A
68 83 FE ; Enable clock terminator for port A
68 6D 80 ; Enable TDM Mode
68 6F 0C ; ADI recommended setting
68 85 1F ; ADI recommended setting
68 87 70 ; ADI recommended setting
68 8D 04 ; LFG
68 8E 1E ; HFG
68 1A 8A ; unmute audio
68 57 DA ; ADI recommended setting
68 58 01 ; ADI recommended setting
68 75 10 ; DDC drive strength
98 F4 80 ; CEC
98 F8 4C ; DPLL
98 F9 64 ; KSV
98 FA 6C ; EDID
98 FB 68 ; HDMI
98 FD 44 ; CP
98 00 1E ;
98 01 25 ; Prim_Mode =101b HDMI-C
98 04 60 ; 27M
44 C9 2D ;
44 BF 13 ;
68 8D 04 ; LFG
68 8E 1E ; HFG
the EDID is copyed from 2.9c
