set_saturate_mode() and __builtin_sat_add
Question asked by bookevg on May 16, 2013
Latest reply on May 20, 2013 by bookevg
So I use VDSP++ C++ and must to use fixed point.
I use the builtin function: set_saturate_mode().
I try why do I need to use set_saturate_mode().
I'm using
int a1,a2,b;
b = 0x80000000;
a1 = __builtin_abs(b);     // a1 = 0x80000000 - invalid result
set_saturate_mode();
a2 = __builtin_abs(b);     // a2 = 0x7FFFFFFF - correct result
// Correct using set_saturate_mode():
int a, b, c;
a     = 0x3fff;
b     = 0x4fff;
c     = a+ b;     // c = 0x7FFFFFFF;
// Invalid using set_saturate_mode() and __builtin_sat_add
int a, b, c;
a     = 0x3fff;
b     = 0x4fff;
c     = __builtin_sat_add(a, b);     // c = 0x80000000;
It's because the code c = __builtin_sat_add(a, b) is
r8     = r15 + r0;                              // r8     = 0x7FFFFFFF and AV     = 1
if av r8     = ashift r8 by 0xFFFFFFE1;         // r8     = 0x00000000
if av r8     = btgl   r8 by 0x1F;               // r8     = 0x80000000
If we want using the same time set_saturate_mode() and __builtin_sat_add VDSP++ must generate the next code:
int a, b, c;
a     = 0x3fff;
b     = 0x4fff;
So it's danger to use set_saturate_mode(). Especialy if you want to use the native support of fixed point in C.
I think we must migrate to CCES when the native support of fixed point in C++ exist and all of VDSP++'s interrupt handlers are support in CCES. At this moment CCES don't support all types of VDSP++'s interrupt handlers. The support is from this forum? but it's not official release.
Or ADI must add the native support of fixed point in C++ to VDSP++
