linux defconfig trouble
Question asked by illishar on May 15, 2013
Latest reply on May 17, 2013 by illishar
I'm trying to create a complete "buildroot" configuration, of my own.
I'm using the newest release: blackfin-buildroot-2012R2-RC5.tar.bz2 + uclibc_full.
Buildroot defconfig can be created with "make savedefconfig". (And copied to the config folder)
The linux config can be created with "make linux-savedefconfig".
The buildroot config defines where to find configs for busybox, linux, etc.
I'd like to place my linux.config in the vendor folder (as suggested by the Buildroot documentation).
Eg. using AnalogDevices config as template, I've copied the linux defconfig to "board/AnalogDevices/blackfin/linux.config". Then I've set the "Using a custom config file" in menuconfig and the "Configuration file path" to "board/AnalogDevices/blackfin/linux.config". There're several other configs (eg. calao_usb_a9g20_lpw_defconfig), that does it likewise.
But it doesn't work! I run the following:
make clean
make distclean
make pch-bf526_defconfig
make menuconfig
make linux-menconfig (this one breaks)
It fails with:
>>> linux custom Configuring
PATH="/home/mk/blackfin-buildroot/output/host/bin:/home/mk/blackfin-buildroot/output/host/usr/bin:/home/mk/blackfin-buildroot/output/host/usr/sbin/:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/opt/uClinux/bfin-uclinux/bin:/opt/uClinux/bfin-linux-uclibc/bin" PERLLIB="/home/mk/blackfin-buildroot/output/host/usr/lib/perl" /usr/bin/make -j1 O="/home/mk/blackfin-buildroot/output/build/linux-custom" HOSTCC="/usr/bin/gcc" HOSTCFLAGS="" ARCH=blackfin INSTALL_MOD_PATH=/home/mk/blackfin-buildroot/output/target CROSS_COMPILE=" /home/mk/blackfin-buildroot/output/host/usr/bin/bfin-linux-uclibc-" DEPMOD=/home/mk/blackfin-buildroot/output/host/usr/sbin/depmod -C "linux/linux-kernel"/ "board/AnalogDevices/blackfin/linux.config"
make[1]: Entering directory `/home/mk/blackfin-buildroot/linux/linux-kernel'
  HOSTCC  scripts/basic/fixdep
  GEN     /home/mk/blackfin-buildroot/output/build/linux-custom/Makefile
make[3]: *** No rule to make target `board/AnalogDevices/blackfin/linux.config'.  Stop.
make[2]: *** [board/AnalogDevices/blackfin/linux.config] Error 2
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/home/mk/blackfin-buildroot/linux/linux-kernel'
make: *** [/home/mk/blackfin-buildroot/output/build/linux-custom/.stamp_configured] Error 2
What am I doing wrong?
I've attached my Buildroot defconfig and my linux defconfig. The rest is the same as the bf526-ezbrd-fdpic_defconfig
