Reducing EMI with shielding
Question asked by bateng on May 14, 2013
Latest reply on May 15, 2013 by MaryMc
I am trying to isolate my AD7794 converter from my microprocessor using the ADUM5010 and ADUM1311 isolators. The isolators would be placed on a separate board, which would be linked via a flat cable to the processor board and ADC board. This way I can easily implement both the isolated and non isolated solution just by replacing the connection cable.
Since my application is in an EMI sensitive environment, I have some concerns about this. Besides standard PCB design measures, I am considering implementing some simple form of shielding, which is very briefly mentioned in the application notes. My questions are:
- is wrapping the isolation board with conductive tape a good idea?
- if I use a metal case, should it be feromagnetic, or is copper also fine?
- should I ground the shield? If yes, should I ground it to primary or isolated ground?
- if I implement shielding, would this compensate for the drawbacks of using a double layer PCB?
Kind regards,
Valentin
