SPORT DMA transmit zero
Question asked by Natasha on May 14, 2013
Latest reply on Aug 27, 2015 by Harshit.Gaharwar
Branched to a new discussion
Hi! I have a problem with SPORT DMA ADSP-21489. Please help me.
I want transmit word 0xAA55. Sometimes transferred wrong zero (or nothing) but CLK is present.
SPORT0 initialization:
void InitSPORT0_TX(void) //Internal - > SPORT0
      int clkdiv,fsdiv;
      //Clear the SPORT control registers (SPCTL0) which flushes the buffers
     *pSPCTL0 = 0;
     asm("nop;nop;nop;nop;nop;nop;nop;");
     //Fastest serial clock speed is fine for the minimum timings
     clkdiv= 0x09;//SLEN-1
     fsdiv = 0x1F;
     // Divisor register for FS and CLK
     *pDIV0 = (fsdiv<<16)|(clkdiv<<1); //internal CLK
     // Sport0 (Tx) control register setup
     *pSPCTL0 = (SPEN_A | DTYPE1 | SLEN16 | ICLK | CKRE |LAFS| FSR | IFS | SDEN_A | SPTRAN);
    //Init_dma_register_tx:
    *pIISP0A = (unsigned int)RMS - 0x80000;
    *pIMSP0A = 1;
    *pCSP0A  = 1;
     return;
SRU initialization:
void SRU_init(void)
  SRU(SPORT0_CLK_O,SPORT0_CLK_I);
          SRU(SPORT0_FS_O,SPORT0_FS_I);
          SRU(SPORT0_DA_O,SPORT0_DA_I);
  SRU(HIGH,PBEN01_I);
          SRU(SPORT0_DA_O,DAI_PB01_I);
  SRU(HIGH,PBEN02_I);
          SRU(SPORT0_CLK_O,DAI_PB02_I); //SPORT master (12.5 MHz)
  SRU(HIGH,PBEN03_I);
          SRU(SPORT0_FS_O,DAI_PB03_I);
return;
void SPORT0_isr(int sig_int)
   done = true;
          *pSPCTL0 = *pSPCTL0 ^ SPEN_A;
          *pSPCTL0 = *pSPCTL0 ^ SDEN_A;
   return;
int done=true;
int RMS=0xCC;
void main(void)
SRU_init();
InitSPORT0_TX();
interrupt(SIG_P6, SPORT0_isr);
InitSPORT1_RX();
sysreg_bit_set(sysreg_MODE1, IRPTEN );/* enable global interrupts */
  asm("nop;nop;");
while(1)
     if(done)
       done = false;
      //Init_dma:
      *pIISP0A = (unsigned int)&RMS - 0x80000;
               *pIMSP0A = 1;//modifier external adress
               *pCSP0A  = 1;//count word for transmit
Here are the settings Sport1:
section("seg_dmda") int A0[64];
section("seg_dmda") int A1[sizeof(A0)];
int TCB_A0[4] = { 0, (sizeof(A0)), 1, 0};
int TCB_A1[4] = { 0, (sizeof(A0)), 1, 0};
unsigned int PCI = 0x00080000 ;
unsigned int OFFSET = 0x00080000 ;
void InitSPORT1_RX(void)
     //Clear the chain pointer register SPORT1A
    *pCPSP1A = 0;
    //Clear the SPORT1 control registers (SPCTL1) which flushes the buffers
    *pSPCTL1 = 0;
    // For internal memory transfers, set up all TCBs in internal memory
    //Proceed from Block A0 to Block A1
    TCB_A0[0] = (unsigned int) TCB_A1 + 3 - OFFSET + PCI ;
    TCB_A0[3] = (int) A0 - OFFSET;
    //Proceed from Block A1 to Block A0
    TCB_A1[0] = (unsigned int) TCB_A0 + 3 - OFFSET + PCI ;
    TCB_A1[3] = (int) A1 - OFFSET;
    // External clock and frame syncs generated by ADC
    *pDIV1 = 0x00000000;  // Receiver (SPORT1)
    // Enabling DMA Chaining for SPORT1 RX
    //Write the address containing the index register value of the first
    //TCB to the chain pointer register, which starts the chain.
    *pCPSP1A = (unsigned int)TCB_A0 - OFFSET + 3;
          // Sport1 (Rx) control register setup
    *pSPCTL1 = (SPEN_A | DTYPE1 | SLEN16 | CKRE | FSR | SDEN_A | SCHEN_A);
  return;
This code is not working properly, if enabled Sport1 to receive codes from the external ADC. When SPORT1 (RX) - disabled, SPORT0 (TX) - work good.  Please help me understand why sport1 violates the issuance sport0.
