Output the PWM signal
Question asked by zcyhansen on May 12, 2013
Latest reply on May 12, 2013 by Aaronwu
now am using the example driver at :
drivers/char/bfin_simple_timer.c
and the driver compile well. And I had insert the modle in my BF537 (running uclinux)
it dose well .
next ,i  write a applications to use the driver to produce the pwm .
the application is follow:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/ioctl.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h> //open function
#include "pwmapp.h"
int main(){
    int fd,result;
    fd=open("/dev/timer7",O_RDWR);// timer7 linkto minor=7
    if(fd==-1)
        return 0;
    result=ioctl(fd,BFIN_SIMPLE_TIMER_SET_PERIOD,3);
    printf("ioctl %d\n",result);
    result=ioctl(fd,BFIN_SIMPLE_TIMER_START,3);
    //result=ioctl(fd,8,3);
    while(1){
    return 0;
and I run this application.  but  the pin cannot  output any signal.
I read the bf537 datasheet:  it said:
"Every timer has a dedicated TMRx pin that can be found on port F ,If enabled, the TMRx pins output the single-pulse or PWM signals generated by the timer. "
so  I  test the PF2 pin    this is my port:(GPIO_UART1TX_PF2)
BUT THIS port cannot test any output.??
