Working sample code or procedure for AD7689
Question asked by AndyR on May 7, 2013
Latest reply on May 8, 2013 by KarenNE
Hi Bindu-
I am re-posting your question as a discussion in the Precision ADCs Community.  Someone here should be able to assist you.
AD7689
Can anyone share a working sample code or procedure for AD7689 as had been trying with it and submission date is near and have already read the posts in ADI for AD7689
Below is the procedure
1)      Procedure for Read Back
Step1:  CNV = LOW
Step2: DIN = CFG =0x3C70 << 2 (Overwrite contents of register, Unipolar, IN0 to IN7 referenced to GND, IN0, Full BW, External reference, temperature disabled,Sequencer disabled, Read back Enabled).
Step3: DIN = 0x00 ( Dummy write,SDO read back CFG)
Note :- When we write 0x00 on DIN line, then the previous CFG will not be overwritten?
If the CFG is overwritten, then what should i do with the DIN line
Step4: CNV = HIGH
2)      Procedure to read IN0 input
Step1:  CNV = LOW
Step2: DIN = CFG =0x3C71 << 2 (Overwrite contents of register, Unipolar, IN0 to IN7 referenced to GND, IN0, Full BW, External reference, temperature disabled,Sequencer disabled, Read back Diabled).
Step3: CNV = HIGH
Step4: CNV = LOW
Step5: DIN = 0x00 (Dummy write)
Note: - When we write 0x00 on DIN line, then the previous CFG will not be overwritten?
Step6: CNV = HIGH
Step7: CNV = LOW
Step8: DIN = 0x00 (Dummy write, SDO IN0 value)
Step9: CNV = HIGH
Bindu
