GuenterL
Re: ADV7619-ADV7511 EValuation platfrom dancing pixel issue
Discussion created by GuenterL Employee on Mar 14, 2013
Latest reply on May 2, 2013 by GuenterL
Branched from an earlier discussion
Please download and run AVES found at http://ez.analog.com/docs/DOC-1789.  The program provides full control of the Blackfin on the eval. board and the ability to run scripts that are included with the install.
I just ran script "PortA,720p,1080i,1080p Any CSpaceIn In 24bit YCrCb422 from ADV761X thru HDMI...." for a UXGA60 input and don't see any image artifacts.  This has a higher pixel rate then you specified in your format.
Can you attach a picture of the noise you are seeing?
The part has been tested up to 225MHz.
