Does linear acceleration effect on bias depend on sign of acceleration?
Question asked by drclaw on May 2, 2013
Latest reply on May 7, 2013 by NevadaMark
Hi There,
I am interested in using the ADIS16445 for my application.
According to the spec sheet, the Linear Acceleration effect on bias is +/- 0.015deg/s/g. Does this mean a positive acceleration will give a positive bias shift and  negative acceleration will give a negative bias shift? Or does it mean this parameter is a statistical one, and the effect of acceleration is only based on magnitude and not the sign.?
For example:
Position 1:     X axis gyro/accelerometer is parallel with gravity(eg pointing down), accelerometer reads 1g (stationary).
Position 2:     X axis gyro/accelerometer is anti-parallel to gravity (eg pointing up). accelerometer reads -1g (stationary).
What is the difference in bias on the x axis gyro in this situation? Is it:
0deg/s (no net change in acceleration magnitude)? Or
0.030deg/s (difference of 2g times the parameter)?
I hope my question is clear, your response is appreciated.
