ADV7441A HDCP Certification Issues
Question asked by br500 on Apr 29, 2013
Latest reply on May 1, 2013 by GuenterL
We are going through HDMI/HDCP certification with an outside lab and we have failed the HDCP test.   The third-party test facility is using Panasonice UITA-2000 (2.0.0.03).  They are failing following register read test which seems mainly on the Ri register as shown below.  Can you let us know if any issues with Panasonic tester as the part works functional with HDCP interfaces (Blue-ray and etc. )
Thanks for your support.
High-bandwidth Digital Content Protection System Compliance Test v1.2
Test ID: (2C-01) Regular procedure: With HDMI Transmitter
Date: 2013/04/12
HDCPTestTool Version: 2. 0. 0. 03
Sink_1.1Features_Supported = No
How to read Ri = Combined format access
(2C-01) 'Regular procedure: With HDMI Transmitter' has started
Data Filename: TMDSdata2C_01_02.bin
>>  TE has started to download the data to UITA-2000
00000: -           ->   read HDCP:   2B from 0x41 (Bstatus)
>>  TE has started the output of TMDS
<<  TE has detected TMDS signal
<<  TE has detected VSYNC signal
00001: -       5ms ->   read HDCP:   5B from 0x00 (Bksv)
00002: -       1ms ->   read HDCP:   3B from 0x05 (Rsvd)
00003: -       1ms ->   read HDCP:   5B from 0x0B (Rsvd)
00004: -       1ms ->   read HDCP:   2B from 0x16 (Rsvd)
00005: -       3ms ->   read HDCP:  12B from 0x34 (Rsvd)
00006: -       5ms ->   read HDCP:  32B from 0x44 (Rsvd)
00007: -       5ms ->   read HDCP:  32B from 0x64 (Rsvd)
00008: -       6ms ->   read HDCP:  32B from 0x84 (Rsvd)
00009: -       4ms ->   read HDCP:  28B from 0xA4 (Rsvd)
00010: -       1ms ->   read HDCP:   5B from 0x43 (KSV FIFO)
<<  TE has detected HDMI signal
00011: -     481ms ->   read HDCP:   2B from 0x41 (Bstatus)
00012: -       0ms ->   read HDCP:   1B from 0x40 (Bcaps)
00013: -       1ms ->   read HDCP:   5B from 0x00 (Bksv)
00014: -       3ms ->   write HDCP:   8B from 0x18 (An)
00015: -       2ms ->   write HDCP:   5B from 0x10 (Aksv)
The first part of authentication has started
00016: -     100ms ->   read HDCP:   2B from 0x08 (R0')
HDCP encryption was enabled
The third part of authentication has started
00017: -    2596ms ->   read HDCP:   2B from 0x08 (Ri')
  [ER-12] ERROR(S301): Ri' (0x00, 0x00) did not equal to Ri (0x7F, 0x9A)
00018: -    2133ms ->   read HDCP:   2B from 0x08 (Ri')
  [ER-12] ERROR(S301): Ri' (0x00, 0x00) did not equal to Ri (0xAC, 0x87)
00019: -    2133ms ->   read HDCP:   2B from 0x08 (Ri')
  [ER-12] ERROR(S301): Ri' (0x00, 0x00) did not equal to Ri (0xB5, 0x25)
00020: -    2133ms ->   read HDCP:   2B from 0x08 (Ri')
  [ER-12] ERROR(S301): Ri' (0x00, 0x00) did not equal to Ri (0xAE, 0x08)
<<  TE has completed the output of TMDS
  [WR-02] WARNING: The displayed image was incorrect
This test was completed
   ERROR: 4 items
   Displayed Picture: NG
=======> FAIL
We do not understand why we failed the test because we are using the Analog Devices ADV7441ABSTZ.  This part requires an HDCP license to purchase, so we believe it should have passed the test.
