Strange output from AD7609
Question asked by jon-ecm on Apr 24, 2013
Latest reply on Apr 26, 2013 by KarenNE
I have a customer who is building a line monitor around the AD7609,
The ADC is connected to the Micro-controller via the 16 bit parallel interface
The solder joints are excellent and all the connections to the ADC have been tested but still this output.
From the data sheet I understand the output is standard 2's Complement Signed, any ideas?
Jon
HEX DUMP:
DB:1-0 is Right Adjusted for combining with DB:17-2
DB17-2 is left adjusted to leave two blank bits for DB:1-0  (Data stored in 32 bit variable so no lost bits )
DB:17-2    DB:1-0   18 BIT Val   2's Complement     GRAPH
00000038,00000002,0000003a,     0000058     |
000000d4,00000002,000000d6,     0000214     |��
00000188,00000000,00000188,     0000392     |���
00000238,00000002,0000023a,     0000570     |�����
000002c4,00000002,000002c6,     0000710     |�������
0000032c,00000000,0000032c,     0000812     |��������
0000038c,00000000,0000038c,     0000908     |���������
000003cc,00000000,000003cc,     0000972     |���������
000003d4,00000002,000003d6,     0000982     |���������
000003b0,00000002,000003b2,     0000946     |���������
00000388,00000000,00000388,     0000904     |���������
00000370,00000002,00000372,     0000882     |��������
00000374,00000000,00000374,     0000884     |��������
00000394,00000000,00000394,     0000916     |���������
000003d8,00000002,000003da,     0000986     |���������
00000448,00000000,00000448,     0001096     |����������
000004d8,00000000,000004d8,     0001240     |������������
00000574,00000002,00000576,     0001398     |�������������
00000614,00000002,00000616,     0001558     |���������������
000006a4,00000000,000006a4,     0001700     |�����������������
00000714,00000000,00000714,     0001812     |������������������
00000758,00000000,00000758,     0001880     |������������������
0000075c,00000002,0000075e,     0001886     |������������������
00000738,00000000,00000738,     0001848     |������������������
0000070c,00000000,0000070c,     0001804     |������������������
000006f4,00000002,000006f6,     0001782     |�����������������
00000710,00000002,00000712,     0001810     |������������������
00000754,00000002,00000756,     0001878     |������������������
000007b8,00000000,000007b8,     0001976     |�������������������  OVERFLOW ON NEXT READ ;(
00000034,00000002,00000036,     0000054     |
000000bc,00000002,000000be,     0000190     |�
00000140,00000002,00000142,     0000322     |���
000001c0,00000002,000001c2,     0000450     |����
00000234,00000000,00000234,     0000564     |�����
00000280,00000000,00000280,     0000640     |������
00000298,00000000,00000298,     0000664     |������
00000284,00000000,00000284,     0000644     |������
0000025c,00000002,0000025e,     0000606     |������
0000023c,00000002,0000023e,     0000574     |�����
0000022c,00000000,0000022c,     0000556     |�����
00000234,00000002,00000236,     0000566     |�����
0000025c,00000000,0000025c,     0000604     |������
000002a4,00000000,000002a4,     0000676     |������
00000304,00000002,00000306,     0000774     |�������
00000368,00000000,00000368,     0000872     |��������
000003c4,00000002,000003c6,     0000966     |���������
0000041c,00000002,0000041e,     0001054     |����������
00000464,00000000,00000464,     0001124     |�����������
00000488,00000000,00000488,     0001160     |�����������
00000490,00000000,00000490,     0001168     |�����������
00000480,00000002,00000482,     0001154     |�����������
00000474,00000000,00000474,     0001140     |�����������
00000458,00000002,0000045a,     0001114     |�����������
0000043c,00000000,0000043c,     0001084     |����������
00000438,00000000,00000438,     0001080     |����������
00000450,00000002,00000452,     0001106     |�����������
00000484,00000002,00000486,     0001158     |�����������
000004bc,00000000,000004bc,     0001212     |������������
000004d8,00000002,000004da,     0001242     |������������
00000508,00000000,00000508,     0001288     |������������
0000052c,00000002,0000052e,     0001326     |�������������
00000540,00000002,00000542,     0001346     |�������������
00000534,00000002,00000536,     0001334     |�������������
00000538,00000000,00000538,     0001336     |�������������
00000518,00000002,0000051a,     0001306     |�������������
000004f8,00000002,000004fa,     0001274     |������������
000004f0,00000000,000004f0,     0001264     |������������
00000500,00000000,00000500,     0001280     |������������
00000508,00000002,0000050a,     0001290     |������������
00000500,00000002,00000502,     0001282     |������������
00000520,00000002,00000522,     0001314     |�������������
00000548,00000000,00000548,     0001352     |�������������
00000568,00000000,00000568,     0001384     |�������������
00000570,00000000,00000570,     0001392     |�������������
00000564,00000002,00000566,     0001382     |�������������
00000568,00000002,0000056a,     0001386     |�������������
0000056c,00000002,0000056e,     0001390     |�������������
00000554,00000002,00000556,     0001366     |�������������
00000530,00000002,00000532,     0001330     |�������������
00000520,00000000,00000520,     0001312     |�������������
00000528,00000002,0000052a,     0001322     |�������������
00000524,00000000,00000524,     0001316     |�������������
00000524,00000002,00000526,     0001318     |�������������
00000538,00000002,0000053a,     0001338     |�������������
00000558,00000002,0000055a,     0001370     |�������������
00000550,00000002,00000552,     0001362     |�������������
0000055c,00000002,0000055e,     0001374     |�������������
0000050c,00000000,0000050c,     0001292     |������������
000004e4,00000000,000004e4,     0001252     |������������
000004d4,00000002,000004d6,     0001238     |������������
000004cc,00000002,000004ce,     0001230     |������������
000004cc,00000000,000004cc,     0001228     |������������
000004e0,00000000,000004e0,     0001248     |������������
000004fc,00000002,000004fe,     0001278     |������������
000004f4,00000000,000004f4,     0001268     |������������
000004c0,00000002,000004c2,     0001218     |������������
0000048c,00000002,0000048e,     0001166     |�����������
00000444,00000000,00000444,     0001092     |����������
00000360,00000002,00000362,     0000866     |��������
0000027c,00000000,0000027c,     0000636     |������
000001dc,00000002,000001de,     0000478     |����
00000180,00000002,00000182,     0000386     |���
00000168,00000002,0000016a,     0000362     |���
00000198,00000000,00000198,     0000408     |����
000001e8,00000000,000001e8,     0000488     |����
00000274,00000002,00000276,     0000630     |������
00000278,00000000,00000278,     0000632     |������
00000248,00000000,00000248,     0000584     |�����
000001e4,00000000,000001e4,     0000484     |����
00000158,00000000,00000158,     0000344     |���
000000a4,00000002,000000a6,     0000166     |�
000007f4,00000002,000007f6,     0002038     |��������������������
00000760,00000002,00000762,     0001890     |������������������
000006f8,00000002,000006fa,     0001786     |�����������������
000006b4,00000002,000006b6,     0001718     |�����������������
000006a0,00000000,000006a0,     0001696     |����������������
000006c0,00000000,000006c0,     0001728     |�����������������
00000734,00000002,00000736,     0001846     |������������������
00000760,00000000,00000760,     0001888     |������������������
00000730,00000002,00000732,     0001842     |������������������
000006c4,00000000,000006c4,     0001732     |�����������������
00000628,00000000,00000628,     0001576     |���������������
00000578,00000002,0000057a,     0001402     |��������������
000003c8,00000002,000003ca,     0000970     |���������
00000378,00000002,0000037a,     0000890     |��������
0000035c,00000000,0000035c,     0000860     |��������
00000374,00000002,00000376,     0000886     |��������
000003a4,00000002,000003a6,     0000934     |���������
000003fc,00000002,000003fe,     0001022     |����������
00000404,00000000,00000404,     0001028     |����������
00000368,00000002,0000036a,     0000874     |��������
000002cc,00000000,000002cc,     0000716     |�������
0000021c,00000002,0000021e,     0000542     |�����
0000016c,00000000,0000016c,     0000364     |���
000000c0,00000002,000000c2,     0000194     |�
00000030,00000000,00000030,     0000048     |
ffffffcc,00000002,ffffffce,     -000050     |
ffffffa8,00000002,ffffffaa,     -000086     |
ffffffb8,00000002,ffffffba,     -000070     |
ffffffe4,00000000,ffffffe4,     -000028     |
00000008,00000002,0000000a,     0000010     |
00000028,00000002,0000002a,     0000042     |
0000002c,00000000,0000002c,     0000044     |
00000000,00000000,00000000,     0000000     |
ffffff98,00000002,ffffff9a,     -000102     |
fffffef4,00000000,fffffef4,     -000268     |
fffffe48,00000000,fffffe48,     -000440     |
fffffda0,00000000,fffffda0,     -000608     |
fffffd14,00000000,fffffd14,     -000748     |
fffffca0,00000002,fffffca2,     -000862     |
