AD-FMCOMMS1-EBZ  + ZC702 problem
Question asked by calex on Apr 23, 2013
Latest reply on May 3, 2013 by calex
i'm trying the AD-FMCOMMS1-EBZ quick start guide with a ZC702 board.
i've already done the same process using a zedboard with success.
But i have trouble using IIO scope tool with the ZC702. There is no link with the FMCOMM.
no output, no input. I know the 2 boards are ok because i can check it with a zedboard.
during the linux boot, i can see strange messages on the console :
[<c0483850>] (kernel_init+0x84/0x130) from [<c000e22c>] (kernel_thread_exit+0x0/0x8)
i2c i2c-0: Added multiplexed i2c bus 1
i2c i2c-0: Added multiplexed i2c bus 2
i2c i2c-0: Added multiplexed i2c bus 3
i2c i2c-0: Added multiplexed i2c bus 4
i2c i2c-0: Added multiplexed i2c bus 5
rtc-pcf8563 5-0051: chip found, driver version 0.4.3
rtc-pcf8563 5-0051: low voltage detected, date/time is not reliable.
rtc-pcf8563 5-0051: retrieved date/time is not valid.
rtc-pcf8563 5-0051: rtc core: registered rtc-pcf8563 as rtc0
i2c i2c-0: Added multiplexed i2c bus 6
ad9548 spi0.2: Unrecognized CHIP_ID 0x0
setting clock to: 154000
raw_edid: e823e880 7
Using YCbCr output
usb 1-1: new high-speed USB device number 2 using xusbps-ehci
ad9523 spi0.3: probed ad9523-lpc
Console: switching to colour frame buffer device 240x75
ad9122 spi0.0: Unrecognized CHIP_ID 0x0
ad9467 spi0.1: Unrecognized CHIP_ID 0x0
at24 6-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
at24 6-0055: 256 byte 24c02 EEPROM, writable, 1 bytes/write
here are the board revision :
ZC702 rev 1.0
AD-FMCOMMS1-EBZ rev B
the console boot result is in the attached file.
regards
