Problem with software interrupt on ADSP-21469 EZ-Kit
Question asked by a.st on Apr 23, 2013
Latest reply on Apr 25, 2013 by MaheshN
Hallo,
I am working on a Code for the ADSP-21469 EZ-Kit with Audio Extension Board. My Code is pretty much based on the talkthrough example. In addition there are UART and pushbutton functionality added. The code for this was taken from the post example. the software can switch between three different matixes. the input signals can be routet freely to the outputs through the matrix. This works well so far. In addition to the physical inputs and outputs I added an interface for an algorithm. The algorithm shall later on work with Blocks of three samples. Therefore I added a counter to the "SPORT1_ISR_process_samples_.asm". When this counter reaches two it is reseted, and bit 18 in the IRPTL register is set:
/* this section increments the counter or resets it to zero */
    r0 = dm(_counter);         // counter value is loaded to r0
    r4 = 2;                    // TODO: check if a push is neccesary
    COMP(r0, r4);              // r0 is compared to r4 = 2
    if NE jump cntinc;
    r3 = 0;
    r0 = r3;                   // sets r0 to zero
    dm(_counter) = r0;         // r0 is written back to counter
    BIT SET IRPTL (1<<18);     // trigger software interrupt at Sig_P15
    nop;
    jump cntend;
    cntinc: r0 = r0 +1;        // r0 is incremented only if countervalue is less than 2
    cntend:
P15I was configured to be an Software interrupt in the main function before:
int temp;
temp=*pPICR2;
    temp&=~(P15I0|P15I1|P15I2|P15I3|P15I4);    // Clear Programmable Interrupt 15 Register
    temp|=P15I0|P15I1|P15I2|P15I3|P15I4;    // Set Programmable Interrupt 15 Register --> Software Interrupt
    *pPICR2=temp;
The interrupt service routine looks as follows:
void test_ISR(int sig_int)
// Loopback for testing
    int i;
    for (i =0; i < AUDIO_BLOCK_SIZE; ++i)
            output_ch2[i]=input_ch0[i];
            output_ch3[i]=input_ch1[i];
After that I used interrupt(SIG_P15,test_ISR). When I now start the program the audio routing works as expectet. But neither the UART nor the pushbuttons work anymore. Without interrupt(SIG_P15,test_ISR) they work as expected and I can switch between different matrixes. With P15 activated only audio works. Can anybody help me to find the mistake in my usage of software interrupts? You find the code I used attached to this post.
Thanks in advance,
Alex
