Re: ADA4817 pspice model correction for Altium use?
Question asked by aym on Apr 22, 2013
Latest reply on May 1, 2013 by NeilJ
I am interested in simulating the ADA4817 op amp. I have downloaded the SPICE model. When I try to run it in Altium I get the following errors:
ClassDocumentSourceMessageTimeDateNo.
[Error]TIA_SW_GAIN_ADA4817 22-4-13XSpiceError on line 129: .model rnoise\xu1 res(t_abs=0)14:54:3122/04/201312
[Error]TIA_SW_GAIN_ADA4817 22-4-13XSpiceUnrecognized parameter [t_abs] in PSpice Resistor model - ignored14:54:3122/04/201313
[Error]TIA_SW_GAIN_ADA4817 22-4-13XSpiceUnrecognized parameter [0] in PSpice Resistor model - ignored14:54:3122/04/201314
[Error]TIA_SW_GAIN_ADA4817 22-4-13XSpiceError on line 130: .model pmod\xu1 pjf (beta=0.5e-2, t_abs=-10)14:54:3122/04/201315
[Error]TIA_SW_GAIN_ADA4817 22-4-13XSpiceUnrecognized parameter [t_abs] in JFET model - ignored14:54:3122/04/201316
[Error]TIA_SW_GAIN_ADA4817 22-4-13XSpiceUnrecognized parameter [-10] in JFET model - ignored14:54:3122/04/201317
[Error]TIA_SW_GAIN_ADA4817 22-4-13XSpiceError on line 131: .model dx\xu1 d (t_abs=0)14:54:3122/04/201318
[Error]TIA_SW_GAIN_ADA4817 22-4-13XSpiceUnrecognized parameter [t_abs] in Diode model - ignored14:54:3122/04/201319
[Error]TIA_SW_GAIN_ADA4817 22-4-13XSpiceUnrecognized parameter [0] in Diode model - ignored14:54:3122/04/201320
[Error]TIA_SW_GAIN_ADA4817 22-4-13XSpiceError on line 132: .model dn\xu1 d(kf=2e-12,af=1, t_abs=-4)14:54:3122/04/201321
[Error]TIA_SW_GAIN_ADA4817 22-4-13XSpiceUnrecognized parameter [t_abs] in Diode model - ignored14:54:3122/04/201322
[Error]TIA_SW_GAIN_ADA4817 22-4-13XSpiceUnrecognized parameter [-4] in Diode model - ignored14:54:3122/04/201323
[Warning]TIA_SW_GAIN_ADA4817 22-4-13XSpicesingular matrix:  check nodes netr5_2 and netr5_214:54:3222/04/201324
I assume that the Altium XSpice is not compatible with the Pspice format. What I need to know is how can I manually modify the file to be acceptable (the "t_abs" does not seem to be readable by Altium)?
I realize that I can use the analog devices  multisim, but we really need to do our simulation within the Altium environment.
Thanx,
Yehuda
