how to compile the driver to BFLT format
Question asked by zcyhansen on Apr 21, 2013
Latest reply on Apr 22, 2013 by zcyhansen
I was using the bf537  the process running the uclinux OS .
and i want to add other driver to the system.   the os support  BFLT format
i  compile the code in my PC and copy the driver.ko to the bf537.
when i using the command:
$ file drive.ko
drive.ko: ELF 32-bit LSB relocatable, Analog Devices Blackfin, version 1 (SYSV), not stripped
so I  think  I shoud  compile the driver to the format of BFLT  ..but how???  this is my  makefile:
obj-m := drive.o
PWD := $(shell pwd)
CROSS_COMPILE_PATH := /lib/modules/2.6.22.18-ADI-2008R1-svn
#CROSS_COMPILE =bfin-uclinux-
#CC :=$(CROSS_COMPILE)gcc
#LD :=$(CROSS_COMPILE)ld
all:
    make -C  $(CROSS_COMPILE_PATH)/build M=$(PWD)  modules
    #make -C $(CROSS_PATH) M=$(PWD) modules
clean:
     rm -rf *.o *.symvers *.order *.mod.c *.ko
should i  using the  elf2flt  ??
