Optimization skips some functions
Question asked by MarcZ on Apr 19, 2013
Latest reply on Apr 23, 2013 by MarcZ
I realized that in my code, there were some function in Debug mode that were not even executed when the Optimization is turned on.
Here is an example:
void TestData(unsigned short* address);
void TestAddress(unsigned short* address);
          unsigned short int datatest;
          for (datatest=0; datatest<32 ; datatest++)
                    address[0]=datatest;
          unsigned short int addresstest;
          for (addresstest=0; addresstest<32 ; addresstest++)
                    address[addresstest]=0xFF;
These functions are almost the same. When the Optimization is not turned on, everything is ok and I can put a breakpoint.
The problem is when I want to turn on the Optimization, I can't put a breakpoint in the TestData function. And the function is not working at all either.
I tried to write it in a example Project exactly like this. Same issue.
Does the Optimization (even the smallest one) can really cause this kind of issue? Because in the future I will need to debug with optimization...
Could you also try this in an example project to see if you have the same issue? I am working on a ADSP-21489 EZ Kit by the way.
Thank you,
Marc
