AD7606 - Cold start (-40 deg C) issue.
Question asked by Roger99 on Apr 17, 2013
Latest reply on May 10, 2013 by maithil
I am currently using two AD7606BSTZ in one of my design. Being in engineering qualifications, I encountered problems at low temperature with one of the two devices used.
Observed issue:
·         Unable to perform cold start on one of the AD7606BSTZ on my board when ambient temperature is -40 deg C.
·         Values returned are all zeros.
Test Sample:
2 x AD7606BSTZ (U31 et U25)
Part No: AD7606BSTZ
Markings: #1130
Markings: 2173586.1
Test steps / Results:
·         Power-off unit
·         Reduce temperature from ambient to -40 deg C (rate of 1degC/min)
·         Soak for 2hrs
·         Perform cold start
·         U25 works fine
·         U31 only transmits zeros
·         Cycle power supply to the unit
·         U25 works fine
·         Shut power off
·         Increase temperature to -30 deg C (rate of 1 deg C/min)
·         Soak for 2hrs
·         U25 works fine
·         Let unit warmup for 30 mins
·         U25 and U31 work fine
·         Power down unit
·         Increase temperature to -25 deg C (rate of 1 deg C/min)
·         Soak for 2hrs
Observations:
Following this test, I looked at all the solders with a microscope and all solders are ok. Wetting is perfect, no cracks in the joints, etc.
Questions:
1)     Any thoughts of suggestions on this issue ?
Kind regards,
Roger
