interfacing AD9951 with MSP430
Question asked by debasish on Apr 11, 2013
Latest reply on Apr 14, 2013 by LouijieC
I am trying to run two AD9951 with MSP430F5436A through SPI. But I am not able to read back from the DDS.
I have tried the following code but it doesnot work.
void portinit(void)
{ P9DIR |= 0xFF;                   //setting port 9 to output port
  P9SEL |= 0x0E;                  //selecting 9.1,9.2,9.3 for SPI
  P9OUT |= BIT0;                  // assert RESET
  __delay_cycles(100);
  P9OUT &= ~BIT0;                 // release RESET
  P9OUT |= BIT4;                  // CSO enable not set
  P9OUT |= BIT5;                  // CS1 enable not set
  P9OUT &= ~BIT6;                 // PWRDWNCTL0 kept low
  P9OUT &= ~BIT7;                 // PWRDWNCTL1 kept low
//................... setting up of port 8 pins.................................
P8DIR |= 0xFF;                      //setting port 8 to output port
  P8OUT &= ~BIT0;                  // IO_UPDATE kept low
  P8OUT &= ~BIT1;                  // IOSYNC kept low
  P8OUT &= ~BIT2;                  //  OSK0  kept low
  P8OUT &= ~BIT3;                  //  OSK1   kept low
  P8OUT |= BIT4;                     //   CLKMDESLCT kept high
  P8OUT |= BIT5;                     //   CLKMDESLCT kept high
//....................setting up SPI............................................
  UCB2CTL0 |= UCMSB+UCMST+UCCKPL+UCSYNC+UCMODE0;   //3wire SPI
  UCB2CTL1 |= UCSSEL1+UCSWRST;                     // SMCLK selected
  UCB2BR1 = 00;                   //divisor clock selected clock
  UCB2BR0 = 01;                   // division by 1
  UCB2CTL1 &= ~UCSWRST;
uint8_t setCFR1_AD9951_1(void)
  uint8_t x;
  P9OUT &= ~BIT4;                                   //CS0 set
  P9OUT |= BIT5;                                       //CS0 disabled
while (!(UCB2IFG&UCTXIFG));
  UCB2TXBUF = 0x02;
  while (!(UCB2IFG&UCRXIFG));
  x = UCB2RXBUF;
  UCB2TXBUF = 0x11;
  x = UCB2RXBUF;
  UCB2TXBUF = 0x12;
  x = UCB2RXBUF;
   // for reading from the same register
  UCB2TXBUF = 0x82;
  x = UCB2RXBUF;
  UCB2TXBUF = 0x00;
  while (!(UCB2IFG&UCRXIFG));                //dummy byte TX
  x = UCB2RXBUF;
  UCB2TXBUF = 0x00;
  while (!(UCB2IFG&UCRXIFG));                // dummy byte TX
  x = UCB2RXBUF;
  return x;
void main( void )
{ WDTCTL = WDTPW + WDTHOLD;
  portinit();
  for (;;)
  { setCFR1_AD9951_1();
    __bis_SR_register(LPM0_bits + GIE);
I have attached the connection between MSP430 and AD9951 chips
I dont have any eperience with microcontrollers so any help will be appreciated.
Thanks.
Debasish
