ADUC 7023 - Internal Temperature Sensor for External Vref
Question asked by xin on Apr 4, 2013
Latest reply on Apr 9, 2013 by ABuda
Dear Sir,
I have a question about REFCON and Internal Temperature Sensor.
I want to use the external refernce source(2.5V) for Internal Temperature ADC.
But I can not get the correct value.
Pls refer to the code, below.  Is there any problem?.
REFCON = 0x03;          // internal 2.5V reference enabled
TSCON  = 0x01;          // Internal temperature chopping enabled
ADCCON = 0x3723;        // Bit 15-14: Reserved
                            // BIT 13: Temperature sensor conversion enable
                            // Bit 12-10: ADC clock speed. 101: fADC/32. 41.78MHz/32 = 1.3MHz
                            // Bit 9-8: ADC acquistion time. 10: default, 8 clocks
                            // Bit 7: Enable start conversion. 1: start
                            // Bit 6: Reserved
                            // Bit 5: ADC power control. 1: ADC in normal mode
                            // Bit 4-3: Conversion mode. 00: single ended
                            // Bit 2-0: Conversion type. 011: single software conversion.
                            // Sample rate: (8+19)clock * 32/41.78MHz = 20 us/sample
    delay( 1000 );
    ADCCP = 0x10;
     tmp = ADCDAT;
    // Start A/D conversion
    ADCCON |= 0x37A3;
     delay( 2000 );
     if( ADCSTA )
        ADCRaw1 = ADCDAT >> 16;
    ADCCON |= 0x37A3;
   delay( 2000 );
    if( ADCSTA )
        ADCRaw2 = ADCDAT >> 16;
    ADCRaw = ( ADCRaw1 + ADCRaw2 ) / 2
     sTemp = ( ( ( ADCRaw * 2500.00 / 4096.00 - 1369.00 ) * 0.22624 ) + 25 ) ;
