Serial port ISR and PPI ISR conflict on 561 EZKIT?
Question asked by DanW0830 on Apr 3, 2013
Latest reply on Apr 4, 2013 by CraigG
I used the Serial code in the examples to do this:
void InstallSerialIsrRoutines()
    // Set up the UART_RX interrupt on IVG8 and UART_Error interrupt on IVG7
    *pILAT = *pILAT | EVT_IVG7 | EVT_IVG8; // clear pending IVG7 and IVG8 interrupts
    *pSICA_IAR3 = Peripheral_IVG(28,8);
    *pSICA_IAR1 = Peripheral_IVG(9,7);
    ssync();
    *pSICA_IMASK0 |= SIC_MASK(28);
    *pSICA_IMASK0 |= SIC_MASK(9);
    register_handler(ik_ivg7, ISR_UART_error);
    register_handler(ik_ivg8, ISR_UART_receive);
    // Finally enable interrupts inside UART module, by setting proper bits
    // in the IER register. It is good programming style to clear potential
    // UART interrupt latches in advance, by reading RBR, LSR and IIR.
    unsigned short temp = *pUART_RBR;
    temp = *pUART_LSR;
    temp = *pUART_IIR;
    *pUART_IER = ELSI | ERBFI;
    ssync();
My serial read ISR works fine until video starts and then when the next character comes in, the serial reader ISR is never called and
the PPI ISR spins here :
rdagain:ssync;
        r7 = [p0];
        cc = bittst(r7, PPI_SIC_IMASK_BIT);
    if cc jump rdagain;
My guess is that the PPI must be sharing some resources used by the UART?
Has anyone run across this issue?
Thanks
Dan
