setting a PWM signal of 100khz in ADuC7060
Question asked by mgat on Mar 30, 2013
Latest reply on Mar 30, 2013 by MMA
Respected Sir/Madam,
We are finding difficulty to set a 100Khz in PWM timer for ADuC7060 in my extract is as follows:
// Bit Definitions
#define BIT0  0x01
#define BIT1  0x02
#define BIT2  0x04
#define BIT3  0x08
#define BIT4  0x10
#define BIT5  0x20
#define BIT6  0x40
#define BIT7  0x80
#define BIT8  0x100
#define BIT9  0x200
#define BIT10 0x400
#define BIT11 0x800
#define BIT12 0x1000
#define BIT13 0x2000
#define BIT14 0x4000
#define BIT15 0x8000
#define BIT16 0x10000
#define BIT17 0x20000
#define BIT20 0x100000
#define BIT24 0x1000000
void ConfigurePWM(void);
#include<aduc7060.h>
unsigned char bTripDetected = 0;
int main(void)
          POWKEY1 = 0x1;
          POWCON0 = 0x78;                       // Set core to max CPU speed of 10.24Mhz
          POWKEY2 = 0xF4;
          // Initialize the GPIO pins for PWM mode
          GP0CON0 = BIT16;                      // Select PWM1 output
          GP1CON  = BIT8 + BIT12           // Select PWMSYNC and PWMTRIP functions
                              + BIT16 + BIT20           // Select PWM2, PWM3 output
                              + BIT24;                     // Select PWM4 output
          GP2CON  = BIT0 + BIT4;           // Select PWM0 and PWM5          output
          PWMCON          = BIT0 + BIT10;           // PWM Standard mode, UCLK/2, PWM Trip interrupt enabled
          ConfigurePWM();                              // Call function to configure PWM
          bTripDetected = 0;
          IRQEN          = BIT17;                     // Enable PWM Trip interrupt source
          while (1)
             if (bTripDetected == 1)
                                 bTripDetected = 0;
                                 ConfigurePWM();
void IRQ_Handler(void) __irq  // Unused in this application
   unsigned long IRQSTATUS = 0;
          IRQSTATUS = IRQSTA;             // Read off IRQSTA register
          if ((IRQSTATUS & BIT17) == BIT17)          //If PWM trip interrupt source
                     bTripDetected = 1;                    // Set flag to re configure the PWM block
                     PWMCLRI = 0xFF;                    // Clear the PWM trip interrupt source
   //Configure PWM0 for 20khz duty cycle
   // P0.4
          PWM0COM0 = 0x80;                    //          Configure PWM0 output high trigger time
          PWM0COM1 = 0xFF;                    //          Configure PWM0 output Low trigger time
          PWM0COM2 = 0x80;                    //          Configure PWM1 output low trigger time
          PWM0LEN = 0xFF;                    //          Configure PWM1 output high trigger time
          //Configure PWM2 for 10khz duty cycle
          // P1.5
          PWM1COM0 = 0xFF;                    //          Configure PWM2 output high trigger time
          PWM1COM1 = 0x1FF;                    //          Configure PWM2 output Low trigger time
          PWM1COM2 = 0xFF;                    //          Configure PWM3 output low trigger time
          PWM1LEN = 0x1FF;                    //          Configure PWM3 output high trigger time
          //Configure PWM4 for 40khz duty cycle
          // P2.1
          PWM2COM0 = 0x40;                    //          Configure PWM4 output high trigger time
          PWM2COM1 = 0x80;                    //          Configure PWM4 output Low trigger time
          PWM2COM2 = 0x40;                    //          Configure PWM5 output low trigger time
          PWM2LEN = 0x80;                    //          Configure PWM6 output high trigger time
