Reading from AD7705 doesn't work, /DRDY doesn't go low
Question asked by matoha on Mar 30, 2013
Latest reply on Apr 9, 2013 by ChrisD.Rama
Hello!
I'm trying to interface AD7705 via SPI with a microcontroller Microchip PIC18F452. The problem is, that the ADC doesn't respond to my communication.
Few things I though where could be a mistake:
- no power - checked, 5.0V
- bad crystal - crystal is up and running (checked on oscilloscope)
- serial clock polarity - in the AD7705 datasheet the polarity is idle high, the microcontroller sends correct clock (checked on oscilloscope)
- data in - the microcontroller sends correct bytes (checked on oscilloscope)
- /CS - tied to ground
- /Reset - tied to Vdd
- bad pin connections - double checked
According to manual, the startup sequence is:
- write to communication register, next step is write to clock register
- write to clock register
- write to communication register, next step is write to setup register
- write to setup register, initiate self-cal
- poll /DRDY pin, wait for /DRDY low --- Problem is, that DRDY doesn't go low
I tried to skip the callibration and write to setup register normal mode instead of Self-cal
- write to communication register, next step is read from data register
- wait for /DRDY low -- DRDY also doesn't go low
What I am doing wrong?
I'm struggling with the ADC for few days and I don't have idea where is the mistake. I simply can't get DRDY low (except turning the power off ).
Thank you very much for your help.
My microcontroller code (the SPI part):
OpenSPI(SPI_FOSC_64, MODE_11, SMPMID);
PORTCbits.RC1 = 0;   //CS low
WriteSPI(0x20);    // next step is write to Clock register
WriteSPI(0x04);    // Clock Register Write CH1
WriteSPI(0x10);   // next step is write to Setup Register
WriteSPI(0x5C);  // Setup Register Write CH1
while(PORTCbits.RC0 != 0); // wait for DRDY low
WriteSPI(0x38);   // next step is read from Data Register
getsSPI(rcvdString, 16);   // read data
