Waiting for root device /dev/mmcblk0p1...   (BF548-EZKIT)
Question asked by uzen on Mar 25, 2013
Latest reply on Mar 26, 2013 by uzen
I'm having two issues on booting uclinux on my bf548 board:
1. "register bfin atapi driver" is failing
I'm not sure if the above is causing the following:
2.  Waiting for root device /dev/mmcblk0p1...
In the serial output though I see the following which I believe is causing problem 1:
"peripheral_request: Peripheral 80 function 1 is already reserved by bf54x-lq043 !"
I'm attaching the .configs and serial output.
Please let me know how I can solve the above issues I'm having.
I followed the instructions for building from here:
http://docs.blackfin.uclinux.org/doku.php?id=buildroot:build-system:build_a_target
-----printenv-----------
bfin> printenv
addip=set bootargs $(bootargs) ip=$(ipaddr):$(serverip):$(gatewayip):$(netmask):$(hostname):eth0:off
autoload=no
baudrate=57600
bootargs=root=/dev/mmcblk0p1 rootwait rw clkin_hz=25000000 earlyprintk=serial,uart1,57600 console=tty0 console=ttyBF1,57600
bootcmd=mmc rescan; ext2load mmc 0 0x1000000 vmImage; bootm
bootdelay=5
ethact=smc911x-0
flashboot=bootm 0x20100000
gatewayip=192.168.0.1
hostname=bf548-ezkit
ipaddr=192.168.0.15
loadaddr=0x1000000
loads_echo=1
netmask=255.255.255.0
nfsargs=set bootargs root=/dev/nfs rw nfsroot=$(serverip):$(rootpath),tcp,nfsvers=3
nfsboot=tftp $(loadaddr) $(nfsfile);run nfsargs;run addip;bootm
nfsfile=vmImage
ramargs=set bootargs root=/dev/mtdblock0 rw clkin_hz=25000000 earlyprintk=serial,uart1,57600 console=ttyBF1,57600
ramboot=tftp $(loadaddr) $(ramfile);run ramargs;run addip;bootm
ramfile=uImage
rootpath=/romfs
serverip=192.168.0.2
stderr=serial
stdin=serial
stdout=serial
ubootfile=u-boot.ldr
update=tftp $(loadaddr) $(ubootfile);protect off 0x20000000 +$(filesize);erase 0x20000000 +$(filesize);cp.b $(loadaddr) 0x20000000 $(filesize)
Environment size: 1139/32764 bytes
Sincerely
Shravan
